No. I don't have the link but the same question has been asked somewhere else, or another thread here.
Still going nuts waiting for this to to come to sidewinders :yawn2:
@Shoggy:
Still on schedule for the end of March? :)
Don't bother. Just check the New Products page daily.
John
With 5 days left in March, I don't think that this will be available in March stateside. Sometime in april is a good guess, the availability may be limited. I am still uncertain as to what the final US state price will be.
For me personally around 150 for the xt version would be acceptable and a good value, anything above that and it would place the purchase under scrutiny by the auburn haired auditor (the g/f).
@shoggy: Is there a remote possibility that you will release a bluetooth version of the remote control?
There will no bluetooth remote available. The hardware was not designed to use something like that. The IR function was already a very late idea that was not in our mind from the start. IR was easy and cheap to integrate while bluetooth would have cost much more and would also add several new problems: the biggest of them is that you need a certification which allows you to use bluetooth. That is pretty expensive and compared to the costs of IR almost idiotic.
Well the hope of turning my comp on with my smart phone it's dead.
Will you be enabling access to aquasuite software at least for remote management/reporting ?
Sent from my X10a using Tapatalk
The aquasuite will get a network remote control in the future and there will be also a SDK available.
SHOGGY .... Since your so chatty today how about a status update on production, testing and shipping.
Thanks,
John
@jcrouse: some day in April.
@MagisD: as said, just from technical side it is not possible anymore.
I think he meant an app that can interact directly with the network service (the "network remote control" you were talking about a couple of posts back) of Aquasuite, rather than having to use the web browser for instance.
I don't know how you are going to implement this, as a web server running on the host machine using Apache for instance or as a separate network service running within Aquasuite, but in either case that's what I think MagisD meant.
The best example I can think on right now is the Server Admin app for iOS devices, which acts like a stripped down version of the Server Admin Tools for OS X Server.
Exactly I know zip about app creation, but I'd love it if aquasuite had an control app to take advantage of the network access.
Real time montioring and control while your running game etc. adjustment on the fly while using system since quite a few people don't op for the screen version. That or long cables so I can mount the screen/controls externally.
Aka nzxt sentry lxe which I have now.
I'm sad that I placed my order only to find out that they won't ship until April :(
Hi, how PA2's can be connected to AE5 and how all these parts work autonomously as one system when USB is down?
Also, flow and temp sensors connected to each PA2, will it be seen from common Aquasuite, i e I may have max upto 7 flow sensors in one single system?
April. I hope that means the beginning of the month and not the end! That is a large time difference!
rioja: PA2 becomes as "sub-part" connected & regulated via aquabus cable. AE5 can also work by itself even without usb, as it features it's own controller with firmware. USB is mostly used for initial configuring, and if wished for - for monitoring via software.
Few questons are still unclear for me.
1) how to link AE and PA?
AE has two 4-pin connectors aquabus
http://forum.aquacomputer.de/images-ac/ae5_lt.jpg
and PA has one (or two?) 3-pin connectors
http://img845.imageshack.us/img845/9264/93157081.png
Do I need special cable or I may make it myself from common fan cable?
2) How to connect two PAs and AE? PA no.2 connect to PA no.1, and PA no.1 connect to AE?
3) If I have flow and temp sensors connected to PA no.1, will it be seen as common sensors in aquaero, so I could program PA no. 2 depending of sensors connected to PA no.1?
