I was able to fix my cold boot issues with the 1253 bios, I'm rock hard stable at 4.6ghz with 1.31 volts, i just think I'm going to leave it at 4.6 it's very fast and doesn't go over 51c even after gaming on h20 :)
Hi,
does anyone know how to revert with ASUS P8P67 DL to the older BIOS ??
EZ flash refuses to do so, is there any AFUDOS eng detition for this MB like there was for the older ASUS MB s ..?
Hi guy
I just finiched my new p8p67 deluxe with 2500k cpu system and the pc wont boot... the cpu led is red. Is it normal? shoudn't be green?
also, I have corsair CM3X2G1600C9DHX memory. I know it isn't in the QVL. Maybe it is the problem...?
Hmm...you did plug both the 24 pin and 8 pin power cords into the motherboard correct? Try resetting the CMOS and I think that Mem OK thing on board is supposed to auto configure your ram or something, but I haven't really messed with it much. Also, try one stick of ram opposed to all of them.
I've found a few other reports on forums via Google with the same issue of BIOS reporting a higher temp after flashing from shipping BIOS and also reporting higher than desktop utilities.
One speculation is that the load is higher under BIOS than Windows, but in my case, perhaps just not high enough to tell based on the temp of the heatsink or fan. I do notice that when I ran 1 thread on Prime95, the temp reached the high 40s. Is it possible that in BIOS one core is 100% load and BIOS reports only the temp of that core, whereas desktop utils report individual cores or an average? I have no other explanation.
For what its worth, the Asus monitor motherboard temp seems to match the BIOS motherboard temp.
Almost done with my testing here...
My 24/7 settings will be 4.6ghz 1.35V
Everyting in the bios was left as DEFAULT, AUTO, OR STOCK, except for:
By all Cores
46
CPU Voltage 1.35V
RAM Voltage 1.5V
I was able to test 4.8ghz 1.4V with Prime95 for 1H using the IN PLACE LARGE FFTs test but I'm not confortable with 1.4V. However, I experienced some voltage drops as low as 1.376V
http://img.photobucket.com/albums/v4...n23/48ghz3.png
orion23, how'd you go running small FFTs? That's a decent 24/7 clock you're running. Love the massive desktop icons lol.
What difference does Win7 SP1 have on stress testing?
Okay this is DEFINATELY weird. Has anyone had a motherboard warning of -60°C before??? Was just doing some Prime95 testing on my Deluxe board.
http://img529.imageshack.us/img529/6025/101x46.png
That is perfectly normal when you are using a software that doesnt work for half the people.
Anyone get past post and then get to a blinking command prompt before it boots OS and it just sits there and eventually reboots?
Cant seem to pass x52 multi whatever I try lol
http://windows7forums.com/windows-7-...available.html
If you want to integrate it into your OS disc, use RT Seven Lite.
So, I forgot to remove the Intel Lan "try me" sticker and after installing the mobo, well sticker still remains there (i've pulled on it but can't really take it off)
Lan works with no issue, but it's got me wondering about the bluetooth adapter....is there a cover on it or is it supposed to be ready out of the box (I ask because the range really sucks compared to my old USB bluetooth dongle..)
Thanks!
