adding another rad.. will help to get this temp down :up:
My 800D :D
http://cbiwebhost.com/pix/images/ocau/pc/CPU-Block.JPG
Downstairs
http://cbiwebhost.com/pix/images/oca...own-stairs.JPG
Overview Top-Half - Need to clean my Radiator :P
http://cbiwebhost.com/pix/images/ocau/pc/Top-side.JPG
Backside Spaghetti
http://cbiwebhost.com/pix/images/ocau/pc/backside
Overall Shot, Cat interested :lol:
http://cbiwebhost.com/pix/images/oca...verall-cat.JPG
Got home from vacation to find my typhoon 4 as promised by Brian from primochill. While it took a year to get through several crappy typhoon 3's , I must admit the new reservoir is awesome. As soon as the typhoon 4 is released to the public I'll get pics of my 800d and the reservoir up.
Thumbs up to primochill for persevering through and finally delivering! And, yes I am very aware of all the issues and I don't give a hoot. Just glad I waited em out and took delivery of what seems to be a great product
I also caught the obsidian fever... :)
http://img529.imageshack.us/img529/185/27092010675.jpg
Ah, memories, side by side old case near new one. That was first strong impression from this enormous case for me aswell :)
Heh same here, When i picked it up from Umart, i was like :O this is huge! put it next to my old case i was like, :O:O:O this is freaking HUGE!!! now i look at my old case, going :O:O that is tiny!!!:rofl:
http://img191.imageshack.us/img191/7900/dsc09701gc.jpg
http://img812.imageshack.us/img812/8840/dsc09682h.jpg
http://img708.imageshack.us/img708/5001/dsc09686e.jpg
EDIT: Wow- resized that picture is a lot better than I thought it was- the first. It looks better at that size than the full 10.2 megapixel version.
EDIT2: My rig is such a hack job. I swear when I went out and bought all the materials I was hoping for such a better outcome. Not finished with it by a long shot- but I just can't help from jumping in with my weak isht
How are these when it comes to getting all the bubbles? I've always had my loop on a bench because I imagined moving these around is quite a pain..
If you let an efficient loop run for, say, a week, won't it self bleed?
Imho superb 700D build. Worklog link (in dutch?).
If your looking to add more rad and need to be more efficient try this With the heat 470's and 480's put out this might be the way to go. I added a power supply extension to gain some room for a cleaner build and discovered that a 3x120 will fit. IT will be tight but its possible. You will need to put inlet /outlet pointing to back of the case and pull the rad all the way front with fans on the back side. this will allow for the 24 pin to have plenty of room and only a few cables on the outside of the power supply will be affected. this will leave about 2" between supply and rad. There are also some edges on the front side that need removed. My build is posted in the liquid cooling build section. Project CARBON
http://img834.imageshack.us/img834/1522/dscn0104l.jpg
http://img834.imageshack.us/img834/5196/dscn0107z.jpg
http://img834.imageshack.us/img834/24/dscn0110y.jpg
hi all :)
thank you all for posting in my thread :)
i´m currently rebulding my wc loop
nearly finnished
http://www.sweclockers.com/image/gal...nal&k=a6bac7a1
GT fans is going to be painted red like shazza did with hers :)
and some BP 45 degree and some BP compression is going to be added :)
Ogge, I see that you've added the rad. Nicely done man :up:
Hows the temp?
Does anybody know if a a PA120.3 can fit in this case?
and please make this rig better with suggestions :)
Corsair Obsidian 800D from Vietnam
http://i1200.photobucket.com/albums/...dwallpaper.jpg
More shots of yours please thienloi, it looks amazing!
Not as awesome as most on here but, I try...
http://i1200.photobucket.com/albums/...f/100_1556.jpg
^^Nice rig, how are temps with the tri-sli?
Ogge_Swe, no clamps, ties, nothing on tubes?? Not recommended.
