Good to hear, I'll be wait'in for the new rev. Cu top.:up:
Has anybody made some improvments on load temps with custom blank metal part?
DO NOT use blank metal part, you might damage pump, burn cpu and so on.
It's only for reason for owner wishing to experiment with cutting his own holes for waterflow in it and only after that it's usable.
I haven't bought this waterblock yet, but somehow i doubt that there is no notice about blank plate in documentation.
Used as is blank plate can fully restrict water flow in loop with all the following niceties like rising temps, pump trying to work without any water movement and so on.
Is there a EK-Supreme-HF with the Red Acrylic top like there is for the normal EK-Supreme-Classified because I REALLY like the way that one looks as it will be put on a classified board?
When I got my EK Classified mobo block the dam red acyclic is scratched, otherwise perfect.
Good thing the POM is so dang nice;)
Eddy, how hard to get a unscratched one:confused:
Hey no problem, just got my D-5 Dual. Very much like.:D
It'll light up nicely, lots of "safe" places to drill LED holes.;)
someone called it clinker @home (forumdeluxx) :shakes:
I love it anyway (Supreme HF CU nickelplated), even though the top should be polished (:p: Eddy):
http://www.abload.de/img/029z9kj.jpg
Heh, forumdeluxx is good for selling/buying but not much else. The attitudes there and general atmosphere really turn me off to that forum.
Just wondering if it is possible to fit 2 45 degree adapters on this block (The CU Version) as it currently is?
Im looking at putting 2 of these http://www.sidewindercomputers.com/bishsi45deg1.html on the block. Considering there isnt enough room for 2 compression fittings, im wondering if there is enough room for 2 of these on the block
how bout considering this
http://www.sidewindercomputers.com/biduro45deco1.html or this
http://www.sidewindercomputers.com/bishsiduro45.html
why...???i think is better for ur fitting can be adjusted abit depends on how good will ur tubing do on a bend.:rolleyes:
here's a bit to share although is not the latest EK cpu wateblock but im happy with this..
http://imgur.com/9oSlO.jpg
and this ur the link to my rig
http://www.techpowerup.com/gallery/2543.html
absolutely no problem. And which fittings do you have? Not every size and type will cause a problem. HF CU with (small) id 3/8 - od 1/2 fittings (a lot of space left):
http://www.abload.de/thumb/05755qy.jpg
And I am pretty sure that the EK-Fittings id 7/16 - od 5/8 will also match (perhaps Eddy could check it)
