Msi 890fxa-gd70 mainboard specs
Originally Posted by
Winchip
MAINBOARD SPECIFICATIONS
Processor Support
AMD® PhenomTM II X6/ X4/ X3/ X2, AthlonTM II X4/ X3/ X2 and Sempron processor in the AM3 package.
HyperTransport
HyperTransport™ 3.0, supports up to 5.2 GT/s
Chipset
North Bridge: AMD® RD890 chipset
South Bridge: AMD® SB850 chipset
Memory Support
DDR3 2133 *(OC)/ 1800 *(OC)/ 1600 *(OC)/ 1333/ 1066 SDRAM (total 16 GB Max)
4 DDR3 DIMMs, supports Dual-Channel mode
LAN
Supports Dual PCIE Gb LAN (10/100/1000) by Realtek® RTL8111DL
IEEE 1394
Chip integrated by VIA® VT6315N
2 IEEE 1394 ports
Audio
HD audio codec integrated by Realtek® ALC889/ ALC892
Flexible 8-channel audio with jack sensing
IDE
1 IDE port by JMicron® JMB363
Supports Ultra DMA 66/100/133, PIO & Bus Master operation mode
SATA
6 SATA 6Gb/s ports (SATA1~6) by AMD® SB850
1 E-SATA/ USB Combo port (back panel) and 1 SATA 3Gb/s port (SATA7) by JMicron® JMB363
Supports hot plug & asynchronous notifcation
USB 3.0
2 USB 3.0 ports (blue, back panel) by NEC uPD720200F1
RAID
SATA1~6 support RAID 0/ 1/ 5/ 10 mode by AMD® SB850
Back panel
1 PS/2 keyboard port
1 PS/2 mouse port
1 Clear CMOS button
1 Coaxial S/PDIF-out port
1 Optical S/PDIF-out port
5 USB 2.0 ports (black)
2 USB 3.0 ports (blue)
1 ESATA/ USB 2.0 Combo port
2 LAN ports
6 fexible audio ports
On-Board
3 USB 2.0 connectors
2 IEEE 1394 connectors
1 Chassis Intrusion connector
1 S/PDIF-out connector
1 Front Panel Audio connector
1 TPM Module connector
1 Power button
1 Reset button
1 OC Dial button
1 OC Dial knob
1 Green Power button
1 Debug LED panel
Slots
4 PCI Express 2.0 x16 slots, support up to PCIE 2.0 x16 speed
1 PCI Express 2.0 x16 slot, supports up to PCIE 2.0 x4 speed (PCI_E4)
1 PCI Express 2.0 x1 slot
1 PCI slot, supports 3.3V/ 5V PCI bus Interface
Form Factor
ATX (24.5cm X 30.5 cm)
Features on Focus
USB 3.0
SATA 6Gb/s
DrMOS inside
Half Hi-C Cap design
Active Phase Switch feature to save power dynamically
OC Genie Lite
OC Dial
Easy Button 2
USB Safeguard
M-Flash included
CrossFireXTM
