http://img688.imageshack.us/img688/9752/p96cl8.th.pnghttp://img716.imageshack.us/img716/9...agineqs.th.png
i think is nothing special!:D
does anyone know if the g.skill ripjaws 1600 cl9's 1.50v models scale with voltage?
on the P55 platform do you know if they can be OCed to say 1900 cl8 by using 1.65v?
Pretty good there keep it up and see how high you can go.
Niiiice...:):)
Can you tell us some voltages(vtt, vdram) for these frequencies...?
DRAM Voltage ~ 1.72v
VTT Voltage ~ 1.36v
:D
With a good kit though that's pretty normal for that chip though.... I wanna see some C6 2400Mhz :D
Nice work though!
what difference are there between kits labeled 9 9 9 24 1.65v and labeled 9 9 9 27 1.60v?
different ics?
Nice kit, just wish Newegg wasn't trying to steal our money with these. DDR3 should be much cheaper by now!!!!
so is this a good buy for the 140 delivered or is there much better deals?
i got them jan for 120, mine do 2100 at 1.6v advertised timings
Latley I start to play this kits again. Really nice kits, but I cant reach that high. 2400 NHz is crazy. 2300 MHz is max for my kits. Higher Vdimm than 1.73 V doesnt really help. :confused:
are these the sticks to get still? I'm more of a timings guy but this seems like it can do CL6 or CL7 around 1600mhz no problem?
how and where are some of you guys getting these for under $100? i've only seen ripjaws at much over $100
I'm currently running 3 of 4 sticks (2 x 4GB kits) in triple channel at 6-6-6-16 @ 1600mhz on an X58-UD5 with an X5677, less than stock volts.
Probably get arreste for posting this but if you wanted to trade a good triple channel kit for my 4 sticks, I'd be interested since I'm not making full use of them on X58 :up:
Really early in the release they were $90 but have gone up since then.
Meh. I probably got some terrible sticks. Tried to run 7-7-7-21 @ 1600 @ 1.64V and HCI Memtest failed =[ this is the beginning of a lot of tweaking so we'll see.
is good 2066 8 9 8 27 1t @ 1.632v real ? from gigabyte sensor
what do you think about it :D?
http://img32.imageshack.us/img32/2521/ramokf.th.png
but is more strong 1820 6 8 6 or 2064 8 9 8?
