Well since we are trying to run the vdd at 3.2 volts or more having the drain of a mosfet using your 3.3v rail is a bit crazy. Drain should be above whatever volts you need and source pin should be higher than the drain pin. Source pin uses the 5v rail. If the source pin used the 12v rail and drain used the 5v rail you'd be able to increase vdd to a lot higher voltage than even some of us crazy v modders would think of using. But in answer to your question and how my ic7 and ic7 max3 works is raise your 3.3v rail at least 0.125 volts above what you set your vdd at. You will still get a bit of a voltage drop. But it may not be that bad. Incresing the 3.3v rail to 0.175 above what you set your vdd at will take care of any voltage drop. So i set my voltages accordingly.
vdd=3.450
3.3v rail=3.625
Yo Minnyboy!!! nice one dude. Glad it works for you.
