DFI has been able to duplicate this issue and are currently working on a fix.
For anyone who is having major problems with the D0 and Elpida at 200x20/2000 memory there is a new ABS file posted. It is for use with the 02/17 BIOS as it has proved to be the best version at getting around the issues users are experiencing.
http://www.dfi.com.tw/portal/CM/cmpr...rue&itemId=561
Like most of the ABS files the voltages are quite a bit higher then most of us use. VTT is set to 1.50V. My board will boot into Windows at that setting but will not pass any stability tests. 1.36V - 1.42V will probably be where most users will end up, assuming an average D0 CPU. After finding the optimal VTT voltage the other voltages can be adjusted while fine tuning VTT.
Boot UP Clock is set to 135. Can try 130 - 160 with 135 - 145 being optimal for most setups.
There will be a BIOS released based on the 05/08 that addresses these issues.
