True ambients make ALL the difference in the world.
I have achieved single digits on air before and my ambient room temp was around
24c. :)
24c. :)
Easy.
Reverse the rear 120mm fan and voila.
And yes zero condensation.
http://i206.photobucket.com/albums/b...ture198zz1.jpg
NaeKuh, it looks like you are exactly right. At least, with the results I've gotten from my rad sandwich so far.
It's been surprising what's happened.... to me, at least.
When I first setup the sandwich, I saw idle temps drop by five degrees, and loaded temps by eight. I was pretty excited. Now, however, I'm not seeing these same results. Honestly, I have no idea why. My ambient is still the same, and nothing else changed, but as of last night, my idle temps were down to a two degree improvement over the single rad, and only four degrees at load (Prime95).
So today the rest of my fans came. I now have 9 fans on the sandwich. And it doesn't matter how fast or slow I turn them, my temps stay exactly the same: 80 at load and 40 at idle. This is on an i7 920 @ 3.6, ambient at 22 C, Coolant temp in reservoir 33 C at load, and 28 C at idle. Not exactly the results I was expecting. I'm very tempted to take the sandwich apart and run them in series. I honestly think that, as you speculated, I'm bypassing my first rad.
Edit: just to be thorough, here's my total setup: Res - eheim 1250 - Swiftech Apogee GTZ on cpu - EK GTX295 WB - MCR320 Rad sandwich - res. My flow rate is exactly one gallon per minute.
Yet another edit: it would be great if Swiftech would include hardware necessary to plumb the rad sandwich in either parallel or series. I'm going to try and track down the necessary connectors to leave it stacked, but plumb it for series flow. I hope it can be done... if anyone could suggest fittings for doing this, I'd really appreciate the help. The hard part is going to be getting fittings small enough to fit between the two rads since I'm using 25 mm fans.
not to bash swiftech, whose products are always innovative, good performers and competitively priced, but i suggest you all to have a look at this:
http://www.xtremesystems.org/Forums/...d.php?t=220874
its not MCR-220-QP-STACK, still explains some things about stacked rads :up:
I think the point is partially lost about why this concotion was brought to market. This stackable concept isn't designed to take the performance crown, although being competitive with the leading rads is an added benefit.
This is designed to squeeze more performance despite space constraints. Most people do not have a colossal case. For the average slim full tower case, there is a limited amount of radiator space. To a moderate degree, this stackable radiator concept helps add more radiator capacity for a seemingly maxed-out situation.
This is not revolutionary... its just evolutionary.
Man, I am glad I am reading this because I was about to do a 9 fan sandwich. This will save me a ton of room. Would running this in series with only 3 fans still be enough airflow?
Also, if I am only using three fans connected to a sunbeam rheobus, what fans would work well? I am more concerned with having enough CFM at load than I am with noise, because I can always turn the fans down when they arent needed. I have some 1900rpm Scythe Kraze fans right now and these things seem to move a lot of air.
Despite the negativity lately in this thread and the negative test report in the other, I still pulled the trigger and bought it. We shall see how it performs. I like tinkering with these kind of stuff. But then again I am a test-engineer :)
This makes my head hurt. I was just about to grab one of these. Now I'm not too sure about it. :dammit:
What to do...what to do....
Not to mention that this product was requested by XS forum members
There was never any question in anyone's mind (at least not in ours) that 1/stackables could never beat separate rads and 2/stackables would suffer a pressure drop handicap compared to a dual row with equal fin count.
the idea was and still is to improve performance in a space constrained environment and at low cost to exiting MCR owners (10's of thousands of them...)
instead of buying a new dual row and throw away your MCR, just get a second MCR and stack it. BANG for the BUCK Gentlemen [EDIT, and Ladies] is particularly important these days.
Hey Gabe....
When are you going to release some formal or informal data from your in house testing?
Bang for the buck is where it is for me, for sure. Even if I end up having to break up my loop, or just run my sandwich in series flow, I'll still end up having spent far, far less cash on my setup than if I went with, uh, "other" triple 120 rads.
I didn't mean for my last post to sound so negative... yeah, I'm a bit disappointed by the overall performance, but there is still so many different configurations I can try with this hardware. I DO NOT regret my purchase in the least.
I will try to have test data available at the same time as gabe to compliment the in-house testing.
Now, I'm off to an appointment with a Dremel and some D12SH12's in my garage (D12SL12's are available in open corner). :up:
