I am surprised you guys and gals aren't running your i7's at 5Ghz air cooled! :)
A.
A.
Updated EasyTune 6 B8.1113.1 on line.....
Hmm, weird.
Bios F4k and bios latency settings are only affecting A channel, B and C channels are totaly different.
Has anyone tried tri-sli on this board yet? I don't know if it's the case or the board but it looks like i'm not going to fit a card in the 3rd slot, with that bit of metal in the way:
http://img.photobucket.com/albums/v481/xellestar/2o.jpg
so far on air I have ran 4.6
ps I had to mod the case and even the third card. I need a case with 8 of those holes in the back (forgot what they are called lol)
http://i252.photobucket.com/albums/h...6/IM000668.jpg
actually I ordered this case and it should work
http://www.newegg.com/Product/ShowIm...e%20-%20Retail
Silverstone TJ07 works fine for tri-SLI. I have two graphics cards (top and bottom) and a PCIe 8x RAID card in the middle without any issues other than needing a single slot backplate for my second GTX 260.
Personally I *LOVE* having the bottom slot for your second video card. It leaves 4 slots (if they hadn't done that ridiculous thing where they cover up the top PCIe slot... I mean, why bother?) usable even with a dual card SLI setup!
Hi guys
just installed new F4K bios and guess what
3800Mhz @ 1.20v :D
BCLK 200
Multi x19
Uncore x16
memory multi x8
QPI/VTT : 1.235v
Vcore : 1.20v LOAD
http://img87.imageshack.us/img87/9391/3800120vev4.jpg
Very Good Bios:up:
regards
Has anyone gotten Vista sleep mode to work in their mobo? It's broken in my new rig, worked perfectly in my old C2D machine.
x58 ud5, vista 64 home, S3 suspend type enabled in bios.
yes it is , you dont have CPu-Z 1.48 or 1.49 thats WHY !!! (your CPu-Z version >>> 1.47) :p:
i have 1.25v In Bios
1.216v idle
http://img210.imageshack.us/img210/244/f4fdq3.jpg
1.20v load
:up:
hi
same error as previous version with Windows Vista 64bit
http://img525.imageshack.us/img525/8601/errole6.jpg
regards
so,you found F4f better than previous versions?
Hmmm, i wonder is my HAF 932 will work with triple sli
Hi again
F4K Bios
220 Bclk
http://img381.imageshack.us/img381/7872/220tj8.jpg
http://valid.canardpc.com/show_oc.php?id=457815
:up:
i think i can say Yes !!! (but only few hours since i flash it)
the same
1.216v idle / 1.20v full
http://img338.imageshack.us/img338/5660/149ow6.jpg
regards
Nice job, what are your other motherboard voltages on? My board really hates anything but autoQuote:
Originally Posted by mascaras
Hi guys
just installed new F4F bios and guess what
3800Mhz @ 1.20v
BCLK 200
Multi x19
Uncore x16
memory multi x8
QPI/VTT : 1.235v
Vcore : 1.20v LOAD
Very Good Bios
quick question for I7 guys.coming from 775 is it a steep learning curve to be able to overclock these x58 setups with any kind of success?
really?in what way is it easier?just reading the threads confuse the heck out of me. so much different terminology i guess.
