ECC function and ICH9R (or RAID in general)?
Was having the devil's own time with the 9010 getting a corrupt volume on Port 1 (secondary port). Tried all sorts of RAM configs, still it would soon error on me either while running or between boots. Decided to get a little crazy, and put a jumper on the "RESERVED" block, a.k.a the ECC funtion disable, and I have had no problems since. I plan to leave the ECC functionality disabled, not for usable RAM, but it truly seems that it causes problems, at least in my RAID0 setup. I have a feeling there is something happening in the ECC that my motherboard's implementation of the ICH9R does not like, or vice-versa. Still working on getting another CF card; a full "erase" vs. just a format did not fix that problem either. Wonder if HW rev. 3.3 has these problems?
Wade
Response tp CF backup issues...
First e-mail....
Hi,
1. For ANS-9010 8*4GB total 32GB,
Memory total capacity: unit:1024Byte
32GB=32*1024B*1024B*1024B=34,359,738,368Byte
ANS-9010 has ECC simulation function and it needed total capacity of 1/9,
so it will be 34,359,738,368 *1/9=3,817,748,708Byte
According to calculate, we can use data of RAM Disk is
RAM DISK - ECC = DATA
34,359,738,368-3,817,748,708=30,541,989,660Byte
CF Card capacity: unit:1000Byte
32GB=32*1000*1000*1000=32,000,000,000Byte
Therefore, we know RAM Disk capacity is less than CF card capacity, so you can feel free and use 32GB CF card to backup / restore data with ANS-9010.
If you are use DIMM with ECC for ANS-9010, we will suggestion move up to next size of CF card. For example, if total RAM Disk capacity is 32GB, please use 48GB CF card for backup / restore.
2. For that button, it is for engineer debug use only, please do not press that button in any time, because it may take risk or cause data lose.
ACARD Technical Support Dept.
FAE-Jack
Mail: support@acard.com
Tel: 886(2)85122290
----- Original Message -----
Sent: Saturday, December 27, 2008 8:43 AM
Subject: <<9700080531>>Help!!--English--ANS-9010
Second e-mail...
Hi,
1. No need do format on CF card before you insert it into ANS-9010 and backup data.
2. The new CF card will copy all ANS-9010 data (included disk partition) if you pressed backup to cf button or auto backup data to cf when power off ANS-9010.
3. When restore data in progressing, CF be removed suddenly, you may see "Backup to CF" LED solid red. 2 solutions for this situation:
A. You can try to remove all power source from ANS-9010 (include battery) and install power source again.
B. Insert CF card to ANS-9010 again.
If you read previous mail, you will find out uses 32GB CF card to backup / restore data from ANS-9010 with 32GB DDR2 DIMM (NON-ECC) should be no problem.
FAE-Jack
Tel: 886(2)85122290
Sent: Monday, December 29, 2008 8:41 AM
Subject: <<9700080662>>Re: Help!!--English--ANS-9010
Third e-mail...
Hi,
If your DDR2 is non-ECC and disable ANS-9010 ECC function (jumper on ECC), too, your ANS-9010 total size will be 32,768MB, but CF card is 32,000MB only, that's why you can not backup and see Backup to CF LED are steady red.
ANS-9010 are provided ECC function (no jumper on ECC) already, it makes date more safety and security, this function take total size of memory * 1/9, meaning 32768-(32768*1/9)=29127, and CF card can fully backup ANS-9010 32GB without any error because CF card size big than ANS-9010 now.
If your DDR2 DIMM is ECC type, ANS-9010 total size will be 32,768MB, but your CF card is 32,000MB only, that's why you can not backup and see red light on Backup to CF LED, so please use 48GB CF with ANS-9010 32GB or downgrade ANS-9010 to 28GB with 32GB CF card for complete backup.
Please beware that power source (include battery) must remove or press button battery connector nearby when you are install DDR2 DIMM.
Please provide your DDR2 DIMM model and ANS-9010 firmware version to us for check more information.
Here is how to check ANS-9010 firmware version:
1. Right click on "My Computer"
2. Click "Properities"
3. Check ANS-9010 on "Device Manager"
4. Refer to attach file "9010-FW 31 32.jpg"
FAE-Jack
Tel: 886(2)85122290
Sent: Monday, February 09, 2009 8:51 AM
Subject: <<9800004593>>Help!!--English--ANS-9010 R 3.1
