http://i30.tinypic.com/w9vayx.jpg
There we go
There we go
Says
VID = 1.2250
There lies the root to your issues. If it is requiring 1.225v just to run stock [3Ghz], then running it higher will require a whole lot. Your VID is .05v more than mine, and my CPU runs at 3.16Ghz [.05v may sound like a little, but with CPUs it is a lot]. I guess you got to chalk this issue to having an average joe CPU. Sorry man.
Some Voltage measurement points for the Asus P5Q3 Deluxe:
http://i30.tinypic.com/10ckj2q.jpg
Telo I know you want to help, but if you don't own an Asus DDR3 P45 chipset based mobo, plz don't give advice on voltages...or settings.. this board sadly has major ram incompatabilities and think we have to wait a few more bios updates before some peeps rigs will fly...
Also VID is nice but there are loads of CPU's that can run stock speeds at a voltage way below the VID... your claim is a so NO sir... if he can run 3.6 stable at 1.25 he should be able to make 4ghz around (sub) 1.4 level
My E8400 reads out as 1.2250 too and yet it almost does 4ghz at it (in fact I need 1.24Vcore), 3Ghz is done at 1volt...
I would return this board asap if you still time left on your return policy, it has been a long time and issues do not seem to be fixed, i had nightmares trying to setup this board with several sets of ddr3....just some advice so people dont loose out on money.
The board is fine I think. I'm running 3.6Ghz, with 2GB of Kingston at CL7 DDR3 1600. It's you 4GB guys that are having problems.
Thank you :up:
Hi
What is the maximum FSB that you can get with Q9450 OR Q9... on this board?
What is the setting to get it?
I can get max 484 x 7.5 one more wont be stable ,or boot, no mater ,what I change
I think i've managed to stabilize my single stick OCZ 1600MHz 2GB memory, but now the core speed flickers between a 9 and 6 ratios (3000 and 2000 MHz, respectively). What am I setting wrong in the BIOS? :confused:
http://img58.imageshack.us/img58/928...4993bt8.th.jpg
