Hi all seems i too have been having these random freezes with this board. Benchzowner i would be very greatful for some direction/help in solving this issue if you had some time. You mentioned getting rid of you striker II what did you replace it with? I just spent a huge chunk of money on this board and am really unhappy with its constant issues(more details after the system info) and would like to as a last resrot replace the motherboard but i am now gun shy and worried ill buy another difficult lemon any suggestions? Thanks a bunch, I have included all the information you request when starting a problem sovling ticket below.
Required System Specifications
PSU ( Power Supply Unit ) = Zalman ZM1000-HP
CPU =Intel Extreme Core Duo QX9650
RAM =OCZ Reaper 1333mhz 2X 2Gig 6-5-5-20
HDD ( the one where you have your windows installation on ) = Raid 0 2X WDAKKS750 SATA(or somthing similar)
VGA1 = BFG Geforce 280GTX OC2
VGA2 ( if you have ) = BFG Geforce 280GTX OC2
VGA3 ( if you have ) =
SPU ( Sound Card ) = Sound Blaster X-Fi Faility ed PCI-E
NorthBridge Cooling = Stock fustion block with Big water 760i Liquid cooling
SouthBridge Cooling =Stock
CPU Cooling =Intel retail stock
RAM Cooling = Reaper Ram heat spreaders
nFORCE Chipset Drivers Version = 9.64
ForceWare/GeForce Drivers Version =180.43 (had issues with 178.X vidoe cards would randomly not load drivers/EQ2
crashes)
Sound Card Drivers Version = Latest
BIOS version 0801 REQUIRED--- i am using 1104
BIOS Settings
Extreme Tweaker
CPU Level Up = Auto
Memory Level Up = PC3-10660(required for this ram to run at stock settings, auto detects as a step lower)
AI Overclock Tuner = Auto
CPU Multiplier = 9X
FSB - Memory Clock Mode = Disabled
FSB - Memory Ratio = AUto
FSB (QDR) MHz = 1333
MEM (DDR) MHz = 1333.3
LDT Frequency = 1333
PCIE Bus Slot 1 & 2 MHz = 100
PCIE Bus Slot 3 MHz = 100
SPP<->MCP Ref Clock, MHz = 200
SLI-Ready Memory = Disabled
Memory Timing Setting
P1 =Disabled
P2 =Disables
tCL ( CAS Latency ) =6
tRCD =5
tRP =5
tRAS =20
Command Per Clock (CMD) =2T
tRRD = 5
tRC = 34
tWR =12
tWTR =15
tFAW =26
tRD =8
tRTP =1
tRFC =74
tREF =7.8µs
Over Voltage- setting on the left, hareware volt reading on the left
CPU Voltage = Auto - 1.29
Loadline Calibration = Enabled
CPU PLL Voltage = Auto - 1.53
CPU VTT Voltage = Auto - 1.13
Memory Voltage = 1.8 - 1.87
NB Core Voltage = 1.56 - 1.6
SB Core Voltage = Auto - 1.50
CPU GTL REF0 Ratio =Auto
CPU GTL REF1 Ratio =Auto
CPU GTL REF2 Ratio =Auto
CPU GTL REF3 Ratio =Auto
NB GTL REF Ratio =Auto
DDR3 CHA1 Ref Volt =DDR_Ref
DDR3 CHB1 Ref Volt =DDR_Ref
DDR3 CHA2 Ref Volt =Auto
DDR3 CHB2 Ref Volt =Auto
CPU Configuration
CPU Internal Thermal Control = Disabled
Limit CPUID MaxVal = Disabled
Enhanced C1 (C1E) = Disabled
Execute Disable Bit =Disabled
Virtualization Technology = Disabled
Enhanced Intel SpeedStep(tm) Tech. = Disabled
CPU Core 2 = Enabled
CPU Core 3 ( Ignore this setting, unless you have a Quad-Core CPU ) = Enabled
CPU Core 4 ( Ignore this setting, unless you have a Quad-Core CPU ) = Enabled
Spread Spectrum Control
CPU Spread Spectrum = Disabled
PCIE Spread Spectrum = Disabled
MCP PCIE Spread Spectrum = Disabled
SATA Spread Spectrum = Disabled
LDT Spread Spectrum = Disabled
Problem Description
My computer will run great for hours.. Prime95 passes for at least 6 hours, memtest Test#5 134 passes np, Intel Burn
Test 5 Passes residuals all the same. The issue is randomly i get these freezes in game or as i load i
game...Prime95 even froze once within 2mins so i rebooted and it passed for 6 hours. I have a feeling this freezing
is comming from a random hickup in the bios or drivers but my experiance is not such that i can proper diagnose or
solve the issue. I doubt its a heat issue, i just got an Antec 1200 case, CPU gets to about 46-53C(it might have
spiked at 55 but the majority of the run was 50 or less) under Prime 95 max load.
