Jcool's RAMBOCK heatsinks RULE
Unfortunately- I couldn't buy them.. to much for shipping.
Those RAMBOCK heatsinks are awesome, I had to get single-pipe ones from www.gogofan.com they are by some other company but the specs on them are very similar except they are single-pipe.
"Masscool RAM Heatsink"
There is another in the UK called Xilence which shares a similar design. But they didn't respond to my email. So I kept looking and found the Masscool Sinks.
I saw a review where sinks like the ones I bought dropped temps on RAM quite well.
http://www.hard-h2o.com/review/disip...-cooler_2.html
So I bought some RAM heatsink clones for my machine :)
ZIO
Xeons from the center of the slice "golden" Processors
HI everyone!
If only there was a way to KNOW beforehand if your processor had a good chance of being golden.
Even though composition is the mostly the same, the molecular order is greater near the center of a crystal either natural or man-made, meaning less growth layers. Calving the chip near a core of a big silicon crystal near the middle lengthwise of the stick of the cuts where perfect temps made for better material.
The appearance of "golden" processors are evidence of this higher crystalline order whereas the processor materials can withstand higher thermal loads and have greater oriented passivity to modulated loads.
It would appear that from the articles I have read on silicon crystal growth that right down the center of the crystal, the orientation will be of the highest order, therefore the chips created from this layer will "perform" best under thermal loads, meaning better overclocking.
If there was only some way to map this- no wait, they do already you'd just have to get the data somehow, before you buy them.....
Now this might vary a little depending upon the actual draw speed and the condition of the equipment/sensors on the actual crystal furnace. But the chips from the center of the rod and the center of the slice will be the best for OC.:up:
ZIO
running temps for my dual harpertown
this might be hot?
100F Cpu0
97F Cpu1
89F M
100F MB
Either loaded down 10% for hours or idle temps remain the same. the cooler stack doesn't even feel warm to the touch, the ram barely so.
I see your temps are lower, do you think this is a problem?
The computer doesn't act slow or anything and it blows past the post screen so fast all you see is some pixels blink- WHOAH!
