The SLI version won't fit, I have tried. The heatpipes sticking out on the side of the contact plate get in the way of some caps, from any mount angle.
The non-SLI version will fit, but not with a GX2. The cooler I recommended only has a single heatpipe sticking out on the side, and you are able to slide it in and out, so it has the best chance of fitting.
