so much talk and no ss. lets see some pics :)
are these multi unlocked?
I had to skew Dram Clocks with in Bios.
Cha A + 150 ps
Cha B + 250 ps
Other Bios Settings
CPU v 1.3875
CPU PLL 1.60
NB 1.69
Dram 2.30
FSB Vtt 1.60
SB 1.175
SB 1.50 1.70
LoadLine Auto
Spread Specrums Disabled on CPU and PCIe
Lavalys shows a little different from Bios Settings
http://img359.imageshack.us/img359/6...50at380tw3.png
http://service.futuremark.com/result...&resultType=14
Time to Drink Now - My Mission has been completed.
What would people say is an "easy" overclock with the X3350? 3.4ghz?
It just doesn't seem as appealing anymore with Q6600s being a full 100 euro cheaper and reaching 3.6ghz easier and the E8400 reaching 4.3ghz easy...
Do any video converters take advantage of all 4 cores? I have tried Super, Any Video Converter, TMPGEnc, iriverter, AutoGK.... all only use maybe 70% of one core and 50% of the other on my dual core server...
So im more inclined to go with fast Dual core than a Quad that may not ever get passed 3.4ghz...
3.40 is easy.
But yes, the new 45nm Quads are just barely fractionally better than the 65nm Quads.
This seems fairly easy:
http://www.xtremesystems.org/forums/...d.php?t=182499
How many people here are using air cooling? Think a true or a IFX-14 would get me to 3.6ghz with a q9450 / x3350?
I use a Lapped Zalman CNPS9700NT. I'll never use Water!!!
hehe I was planning on water but its to damn expensive :P
Going with a IFX-14 or a True now I think
Only one at the moment. :p
http://i235.photobucket.com/albums/e...P5E-VMHDMi.jpg
^= What I've found thus far. Sanding those resistors help... but will take forever...
Sand Away those Resistors!!
Yes! :D I actually did (just a bit, though... an hour was too long for me...) and now my real vNB is at 1.735v. :)
Batch # L803B322, packed 03/26/08. Maximus extreme, Vcore 1.4 VPLL 1.63 (1.56 bios), VNB 1.57, increasing did not help (maybe cause of overheat?) FSBT 1.4V cpu gtl x63 (max) nb x67
Can't break 450x8 stable... posts ok till 480fsb, crashes shortly after starting any sort of testing program. Same wether im running 1400's memory or 1800mhz.
I might be having nb temp issues, im not watercooling my maximus extreme anymore..
do I have the highest oc on x3350? I haven't seen any screen over 490 fsb
http://www.xtremesystems.org/forums/...1&d=1208008378
Well, 495 was bootable, and I wouldn't have been able to validate 500 if I couldn't get into Windows. 490 was the max benchable, though. :) 3DMark06 score:
http://i235.photobucket.com/albums/e...C/MaxBench.jpg
I've a Xeon X3360, but I think I have a FSB wall at 444Mhz, what is incredible low. What are your BIOS settings? I think that the CPU can get higher.
I know... and I apologize for the lack of pictures. :) There isn't anything useful anyway... as this Raidmax PSU that I have at the moment won't let me stay stable at any settings other than stock. In two days, maybe I'll have shots of completely stable overclocks on the Q9450 soon. :) Or actually, wait a sec, I'll see what's the max clocks I can boot into Windows with right now. :p (I can at least take shots from Windows)
BUMP! And FYI! :p:
http://i235.photobucket.com/albums/e...PC/40GCPUZ.jpg
I believe that voltage would be the stable volt for 4GHz... but I can't confirm it until I have some better stuffs two days from now...
Edit: And the graphics adapter doesn't show in the validation for some reason. D:
Grrr... onboard GPU doesn't show... :( But you should know that it's there... hence Vista Aero (look at the window of CPU-Z)
Anyway, 505 FSB! Seems like the northbridge volt mod... works! :D
http://i235.photobucket.com/albums/e...C/404GCPUZ.jpg
And... I wonder if I should...
http://i235.photobucket.com/albums/e...PC/40GOCCT.jpg
Edit again: OCCT crashed after 2 seconds into the stress test. And here's the validate link:
http://valid.x86-secret.com/show_oc.php?id=345603
Finally received ONE of the two I ordered:
L803A756
Installing it soon.. :D
