3oh6: Does putting the pagefile on eram have any benefit?
Not really a 32M LCC but it was my 40 GP performance :)
4002.7......Jmax_oc............10.58.109...8x500.. .....1000mhz....7-6-5-18....1/2...X48
http://www.jmax-hardware.com/ftpjmax...10mn58s109.JPG
P45 and DDR2 power :D
9.xx
4581.8......andre X_X............9.59.250...8x572.. .....572mhz....4-4-4-4....1/4...P45
http://www.plikimage.com/images/9Zm29470.jpg
10.xx
4053.8......andre X_X............10.59.843...7x579.. .....579mhz....4-4-4-4....1/4...P45
http://www.plikimage.com/images/NXE29446.jpg
very nice runs andre!! what tweaks were you using (other than spitweaker)?
andre X_X what is the program "Tweaker V.1.0 beta" ?
@THeKarmakazi: just turn off lots of services, set largesystemcache to 1, running Core0 and realtime priority... you can find more tweaks on before's website here (http://beforeoverclock.com/blog/?p=9)
@DeDal: it's Monteboy's Superpi Tweaker.... im sure he post download link in this thread or you just pm him for the software :)
32M wasn't my best friend till 2 months ago, but i worked really hard on it and now i'm pretty happy about my scores. I'm not yet a master of 32M but i gained 11 seconds from my best score, only by tweaks of course :D
Here's my 10x score:
Asus Rampage Extreme
2x1024 G.Skill PC12800
E8600
Ati 1050
http://www.xtremehardware.it/forum/p...php?n=1725&w=o
Here you can see the difference with "green oliva" theme, the time was a bit worse...classic is the best for me.
http://www.xtremehardware.it/forum/p...php?n=1724&w=o
And that's for 11', same setup:
http://www.xtremehardware.it/forum/p...php?n=1726&w=o
Getting to grips with this P45 mobo, MHz for time sucks but i will try to improve.
http://img.photobucket.com/albums/v6...2Msub11min.jpg
Seems like cas4 1:1 works better on the P45.
LOL, i just saw that CPU-Z says i have DDR3, thanks for the free upgrade CPU-Z! :D Rampage Xtreme, here i come! :lol:
11.xx Category
M/B: ASUS Rampage Extreme (Bios: 0403.ROM)
CPU:Core2 Duo E8600 Q820A599
Memory: CellShock DDR3 1800 1GB x 2
VGA:MSI NX7900GTO 512MB PCI-EX
HDD:Maxtor 6Y080P0 (IDE)
Vcore: 1.4000V @BIOS (1.384V @CPU-Z)
Vnb: 1.60372V @BIOS
Vdimm: 2.21331V @BIOS (2.252 @Acutual)
MEM: 5:8, CL7-6-5-16-AUTO-48, 2T, Auto for the rest in BIOS
OS: Windows Server 2003
http://homepage2.nifty.com/NewBeetle...28_3.6G_RE.png
wowza, let me be the first to welcome you to the 32M LCC Newbeetle-san! i think i speak for all of us LCC veterans when i say, it is a pleasure and honor to have you here. i look forward to some more work from you here...that 7.XX category is rather empty, perhaps you should do something about it ;)
Look at the list again Jody, this isn't his first time here. ;)
Lol, someone correct my result on 11x...you wrote 3997 like on my 10x score but i used 3613.9! it would be horrible if i really had to use 3997 also on 11x :rofl:
bah, sorry guys...i had them right in my text file, must not have updated the first post after i finished editing. thanks for the heads up...if you notice anything else weird just let me know.
as for NewBeetle, sorry about that mate. i took a quick scan but admit i didn't even look at the blue times. but yes, first time i have posted a NewBeetle score...my bad ;)
just running with the same 3D setup i have been working with in my RE Live OC Report so definitely not optimal.
E8600ES (Q814A526) 6 x 595 (boot at 600*6)
Thermalright Ultra-120
Stock MB cooling (air heat pipe attachment)
G.Skill F3-12800CL7D-2GBHZ
2 x ATI HD4850 CF
Seagate 7200.9 80GB SATA2 (10GB partition for OS/SPi)
Silverstone Zeus ST56ZF
WinXP Pro SP2 (custom nLite'nd job)
realtime / core 1
maxmem = no maxmem, windows won't load on this setup
copywazza = 1.85GB (ZIP file) from C:\ > D:\
C:\ = SPi folder
visual effects all off
memory usage = "System cache"
processor scheduling = "Programs"
page file = 300MB/300MB C:
plenty of services disabled but not all
3574.7MHz SPi 32M = 11m 59.406s
click for full size including memset...
http://img.photobucket.com/albums/v2...x_3574-1sm.png
this isn't my normal 32M OS but i don't have that done for the RE board yet. just wanted to get something into the 11.XX category. all i can say is that this board is like cheating...so damn easy to run fast ;)
here is my contribution:
P5E3 PremiumX48 on xp32 pro sp2.
http://images4.hiboox.com/images/350...c21a04b312.jpg
2x the same cpu-z window :p:
11.xx Category
M/B: ASUS Rampage Extreme (Bios: 0501.ROM)
CPU: Core2 Duo E8600 ES
Memory: Corsair Dominator CM3X1024-1800C7D @
VGA: PCI
HDD: 1 X Crucial SSD drive and 1 X I-ram
Vnb: 1.76V @BIOS
Vdimm: 2.2V @BIOS
MEM: 5:8, CL7-6-5-15-1T, memset Used to tighten up settings
OS: Windows Striped XP
3599.6 MHz SPi 32M = 11M 53.937s
http://i46.photobucket.com/albums/f1...0/10014c5a.jpg
One more in the 11.xx with ddr2:
http://img161.imageshack.us/img161/5370/1126xr0.jpg
After some long and hard work trying to find out why my 32M times were so bad i found out i had to set execute disable bit to disabled and plug and play os to no.
I don't know which of those 2 helped me but now i finally am back in the race.
Here's sub 12 minutes:
http://img.photobucket.com/albums/v6...s/32Msub12.jpg
And here's sub 10 minutes:
http://img.photobucket.com/albums/v6...s/32Msub10.jpg
There's some work to be done, want to get sub 12 at <3,6Ghz and sub 10 at <4.5GHz but for now i'm happy.
This Rampage Extreme sure is good at 32M!! :yepp:
Had to do a sub 11, just for the sake of it :D :
http://img.photobucket.com/albums/v6...11min40148.jpg
Not really happy with the result, i was expecting to hit this goal at 4GHz flat.
Appearently my OS needs some more tweaking.
