Honestly this is disappointing, i awaited better results.
I think your results isn't _that_ much better than my current system in Crysis:
CPU Benchmark
TimeDemo Play Started , (Total Frames: 1500, Recorded Time: 44.62s)
!TimeDemo Run 0 Finished.
Play Time: 41.42s, Average FPS: 36.22
Min FPS: 5.32 at frame 528, Max FPS: 60.20 at frame 364
Average Tri/Sec: 37093216, Tri/Frame: 1024226
Recorded/Played Tris ratio: 0.70
!TimeDemo Run 1 Finished.
Play Time: 32.02s, Average FPS: 46.85
Average Tri/Sec: 48124512, Tri/Frame: 1027204
!TimeDemo Run 2 Finished.
Play Time: 31.80s, Average FPS: 47.17
Average Tri/Sec: 48349576, Tri/Frame: 1024900
!TimeDemo Run 3 Finished.
Play Time: 31.97s, Average FPS: 46.92
Average Tri/Sec: 48306208, Tri/Frame: 1029438
TimeDemo Play Ended, (4 Runs Performed)
GPU Benchmark
TimeDemo Play Started , (Total Frames: 2000, Recorded Time: 111.86s)
Play Time: 57.96s, Average FPS: 34.51
Min FPS: 25.48 at frame 137, Max FPS: 41.22 at frame 979
Average Tri/Sec: 34903392, Tri/Frame: 1011544
Recorded/Played Tris ratio: 0.91
Play Time: 55.34s, Average FPS: 36.14
Min FPS: 25.48 at frame 137, Max FPS: 42.72 at frame 1001
Average Tri/Sec: 36923580, Tri/Frame: 1021598
Recorded/Played Tris ratio: 0.90
Play Time: 55.33s, Average FPS: 36.14
Average Tri/Sec: 36925548, Tri/Frame: 1021635
Average Tri/Sec: 36908488, Tri/Frame: 1021218
Could you post such complete results also from your system?
May be we can figure if there are differences for example at the minimum fps, which is the most significant number because it causes the fps lags.
