hmmm 1.3 that's bad news
Maximum Volt Mod
just gotta see now whether that OVP point that was pointed out earlier in the modding thread will work....just need to get someone to test this out now
Is it possible to do the OVP mod by penciling the resistor? If so I'd be willing to play guinea pig.
i don't think bios can select that much voltage
from what people are reporting max 1.2v
so you have to hard mod but if only 1.3v it is not worth it unless you are going to push it on DICE
Just ordered my Palit 3 phase 8800GT! Will be here in 3 days.
http://www.xpcgear.com/be880gtt3.html
Hurry up, they still have stock!
It doesn't say phase 3 anywhere on it and the picture even says "Actual item may differ from image shown"
The part number doesn't come up on google, and the reference name is like this one:
http://www.hardwareschotte.de/hardwa...GT+NE8800TT352
Their main webpage doesn't list a product or part number either :/
Be wary...
Not a good sign.
okay doing the mod. now. Freaked out this is my 1st one. What do I do 1st/
I have 1kohm vr ready to go and wire from a fan. multi meter =/ good rosin core 2.5 oz .032 diameter solder. HELP
using this as a guide http://www.xtremesystems.org/forums/...1&d=1194114049
Ok Mod BIOS and overclock testing again:
This is Max shaders i tried the next step but it is 2000MHz a big jump, not max core yet, vRAM didnt play much but at least it didnt get worst that before the mod.
http://i191.photobucket.com/albums/z...-1944-1035.jpg
I have no idea. I measured the OVP resistor and got 3.22k So I penciled it down to 2.77k and it seems to have done the trick!
I'm now able to set vGPU to 1.35v which is 1.4v under load! I played a 1/2hr. of CoD4 without any issues. I used to get a black screen after less than a minute.:D
It would be nice if one of the experts could tell me what the proper resistance should be for the OVP mod on GT cards.:rolleyes:
Well I am hoping my RAM will fare better w/ a little extra volts. I was only getting 929 stable earlier. Now it seems 951 is stable...gonna try a little higher. I know 972 isn't stable. I don't understand why doing the BIOS mod would affect the maximum RAM clocks, but I'm not complaining. Maybe they just needed to break in?
Yes, I did the BIOS volt mod. I just want to thank you guys for the valuable info, and thanks to Mavke for his hard work!
I was only getting 712/1674/929 (pretty low) stable earlier on my vanilla GT. I actually got a card w/ stock 600/1500/900 clocks despite the fact a lot of folks got SC factory clocks on their vanilla GT's. (got it through eVGA's step-up...320GTS-->GT)
Now I'm getting 741/1728/951 artifact free under ATI Tool...so far. Temps are 70 on the stock cooler w/ 100% fan.
Next step is to get the HR03GT (when it's released), and a good fan on there. Then some VRs will help me get in the 800/2000's...I hope!
edit: I may just leave my RAM alone if it'll run at 950. No use to go higher until I understand better this rumor I hear of the RAM dieing if you OC it to 1000.
so is the bios mod working for you guys????? if so can you share a screen shot of the bios settings....thanks.
