So what you say is that you haven't seen "THE" gain out of it and it's a bit worse than Copy Waza?....
I'm not going to say anyone is cheating as long as I think the score might be possible with some crazy tweaks. When I get my new HD and P5K tomorrow I'll try running the exact same subtimings and frequencies as yours together with the CDT-IV and some other tweaks and see if I can beat my own personal record @ 3,6G (which is not too good anyways :p:).
@ OPB: Did you use any other tweaks in that 13.75sec run? And could you tell me what theme you're using? Thank you :)
On one hand, that's right buddy, no magic gain, not as efficient as another cw method.
On the other hand, it was said to be 60% of The method so if we believe that... what can we conclude if we don't know the remaining? :)
TBH, I prefer my method ATM... not as time consuming as 60% of CDT are, and little faster.
I was just curious.
Before, are you using a .BAT file to do CW? :o
Im ashamed...
RAM EEPROM programmer
Is that freeware, and if not, where can I buy one...? I'd really like that, especially with my new DDR3 =)
.... Sorry for the off topic part above...
Kevin, I'd really like you to explain that neat result... I must admit, I find it obvious as fake... - I'd really like you too explain, cause, you dont admit it being fake - I really have something to learn from you if its valid... - My SPI 1M product is usually between 49800-51000, depending on ram speed and timings...
For what it's worth Kevin you got my apoligize.
You finally showed something that worked so it's all fine for me.
Those that are still on amd should try the tweak, those that are on intel should reconsider their steps in applying it.
At first i couldn't get it to work either, now i shaved of 0.8secs SPI 1M.
I have a C2D laptop but for some reason superpu won't run on it otherwise i would have proven the tweak on that system as well.
I don't get it, totally puzzled here.
Freeing up the available memory works fine, i even got up to a point where i had more avaialble memory than system cache (see pic) but it gives me ZERO gain in terms of SuperPi.
Did all what it takes, maxmem set to 600, 512mb fixed pagefile on the same partition i run SuperPi from (D) free'd up the memory with this tweak but got no love. :(
This is al i did and like said
stock cpu + maxmem at 680 =29.4secs
stock cpu + maxmem and this tweak = 28.8, 28.6 when i push it even more.
Now there IS something - I wonder if you randomly choose 30/40 people on this forum and asked them to explain how to do the "copy wazza trick" how many different ways you hear? 5, 10, 15?!
Everyone seems to have their take on what needs to be done - even if you do it the same the error margin isn't exactly small as I'm sure you or anyone else who's tried this is aware.
In all honesty we'd be better off agreeing on what exactly IS the correct copy wazza process, then making a comment on what exactly OPB is trying to do here as well. I fear however neither of these will get resolved anytime soon :(
*edit*
Eva you ever get a chance to see this:
http://3oh6.com/forum_posted/ocx/jas...pywazza-1.html
it's quite good - watch it (maybe a few times) and tell me who it stacks up against with you've done things in the past, may be of some use?
What wrong with your explanation, Johnny? (http://www.ocxtreme.org/forumenus/sh...38&postcount=3)
First I must say I applaud the work that OPB has done explaining this on OCX. Next it would be great to see more posts in this thread with results. I planned to run stock vs. CW (if anyone wants me to use specific numbers for this or a specific method feel free to say so) vs. CDT last night but had a problem with my OS install. If I can't resolve it this evening then I am sure I will have time to on saturday. I know in the past the large gains had been disputed at the same time I must admit the descriptions of Super Pi (how it works, and what part of the system is used for each section of calculations) I have seen from OPB have exceeded any I have seen anywhere else. Finally I would like to think I am a very neutral party in this dispute. :up:
CES is coming up fast and I can arrange a bench off. :rofl:
If that doesnt work we can take it over to fight club and use their cage. :shrug:
Tweak seems to have a opposite effect on intel, can't figure out why.
I have installed xp instead of Vista on my laptop
and stock i get 23.2secs
with tweaks applied like on the amd system i lose time instead of gaining !:confused: :shocked:
23.5
don't know why though, will try to figure it out later today .
Just wanna say one thing Kevin...note my usage of the words "readily explained." Not once did I use the word "cheat"...you're the one that brought that up. We're ready for any sort of an explanation. Even reading you clearly state that you're using your EEPROM programmer would be some progress. ATM, as I said, we aren't getting anything but flames out of you. :shrug:
Get the cage ready Charles, and I'll get my popcorn ready. Give the guys a couple of months to hit the gym first to make it enjoyable for the rest of us. :p:
What's an EEPROM programmer anyways? Some kind of software? :hitself:
