Will do :up: by the way there $10.99 @ petra's
Nah sorry mate it's not listed on the packaging i had a look for ya...
But i found this....
http://www.overclock3d.net/news.php?...tic_pressure/1
hope that helps...
I will also be trying scythe's newest fan the slip stream series.. they are in stock @ petra's
this one.... 33dba 88cfm 1600rpm
http://www.petrastechshop.com/12scsysstcaf3.html
I'm just playing with the fan's i have atm...
I was surprised how quiet my Xinruilian RDL1225S 120 mm fan is and seems to blow a fair bit of air... i wish i had the tools to measure cfm/dba
cheers!!
Wow, these fans are sexy... Might look for them sometime in the future. Keep it up!
Thanks for the link disruptfam. :up: Tells me half of what I need to know before buying. Now, just need to wait for you to get your SM's and tell us what you think.
Sexy case,great work ı want to continue.
update!!!
Got my Petra order 2day...check it out.....:up:
Was looking forward to getting this beauty !!:)
http://img141.imageshack.us/img141/2...rder002qu7.jpg
http://img228.imageshack.us/img228/8...rder003qe4.jpg
http://img161.imageshack.us/img161/4...rder013di9.jpg
Eddy i commend you on this beautiful block!! :clap:
Scythe's new slip stream series fan...
http://img235.imageshack.us/img235/3...rder004rh8.jpg
http://img210.imageshack.us/img210/2...rder007bm8.jpg
good ol yate loon d12sm _12 :) Wanted to test this against my new scythe ultra's kazes and scythe slip stream fan's
http://img407.imageshack.us/img407/2...rder008qq0.jpg
scythe fan's i got from petra... 2 x 80mm and 1 slip stream...
http://img70.imageshack.us/img70/869...rder005vh9.jpg
That all for now fellaz :up: :up:
Will be mounting gpu loop block next.... finishing drilling/cutting case etc....and testing fan's More pic's to come soon... :)
ENJOY!!!
Your project makes mine looks like shi* hahaha.
Congratz...can't wait to see that box finished :)
Rbs.
:wave:
question fellaz:
with the mounting if the ek block... i put the o-ring then distancer than barb? is that correct???
and the un-used hole's i put the plug in???
don't want to mount it incorrectly
cheers guys
ok mounted the ek block... took about 45mins lol very fiddly....abit of pita really but it looks great... post pic's soon
cheers
I don't care 'bout no stinkin' EK block!
I don't care 'bout no stinkin' slipstream fans!
I don't care 'bout no stinkin' 80mm fans either!
I want test results comparing the YL to the Ultra Kaze's....NOW DAMMIT!
:p: ;) :lol2:
Barbs on copper side = no spacer.
Barbs on delrin or acrylic side = use spacer. Spacer o-ring seals to block, barb 0-ring seals to spacer.
What you're doing is ensuring the barbs' threads don't protrude into the water chamber. So everything depends on what barbs are used and where.
Bloody amazing how fast Quoc can get stuff to us in Oz. Faster than many locals do.
Awesome :)
Waiting for pics!
BTW: I told ya! Those block are a bit of a pita to hook on a 8800GTX.
cheers mate cleared that up for me.... had the spacer both side's lol will fix...
Yeah Petra is awesome ordered Friday got Tuesday... now that's service!!!
Thanks guys @ Petra's!!!
EDIT: fixed the block... will take off 2morow to check tim distribution then back on again :)
Pre-min fan result's
Fan's tested
Yate loon D12SM-12 33dba 70cfm
Scythe slip stream 33dba 88cfm
Scythe ultra kazes 32.91dba 87cfm
Xurillian fan 32dba 70cfm
D12SM: the quietest @ high,med and low out the 4 fan's tested pushes more than the Xurillian but less than the scythe's... surprised how quiet it was :)
Xurillian: Pushes the least air, @ all setting's has annoying rattling noise @ all setting's
Scythe slip stream: Pushes more air than the d12sm and xurillian @ all setting's Inaudible @ low very quiet @ med and noticeable but not to bad @ high
Scythe ultra kasez: Pushes equal or a tad more compared to slip stream inaudible @ low quiet @ med Pushed most air , loudest out all four fan's tested @ high.... by a fair bit slight whining noise and rattling noise (might be faulty fan will test another 1 to be sure)
Results after a very quick test... looks like a 3 horse race here d12sm,slip stream and scythe ultra kaze more to continue tomorrow :)
You do know I was just messing with you...right?
I wish ground was that fast.:( I ordered last Thursday and won't get mine until this Thursday. If I order UPS ground from anyone else, I get it in 3 days. I'm not spending another ~$8-9 (I can't afford) to get my stuff 2 days faster. This is about the only area I see that Petra needs to improve upon.
Hmm, from these results, it looks like I stay with the SM's. I'll wait for full results before deciding for certain though.
SMALL UPDATE:
Mounted ek block got and got my d-tek fitting and alot of tubing!! 25ft to be exact :)
http://img217.imageshack.us/img217/3...rder014cq4.jpg
http://img215.imageshack.us/img215/9...rder015dt6.jpg
http://img339.imageshack.us/img339/6...rder016tg2.jpg
http://img267.imageshack.us/img267/9...rder017dh4.jpg
25ft of masterkleer so cheap :)
http://img401.imageshack.us/img401/9...raorderri4.jpg
that all for now...
Next fan result's and modding of my v2000 case enjoy!!!
You know its just a couple of drill holes and some filing to make your own single slot end plate.
I bought one in a pile of stuff but its very easy to make from a spare blanking plate.
25ft on tubing...
