FSB 466 & 470 * 8 PRIME STABLE Preliminary Results !!!:
So I've being trying to stabilize my rams all night and I finally found out what makes my system having difficulties getting Prime Blend stable.
You guys probably have all seen my current highest OC on air with Prime Small FFT stable screenshots but with the same settings, Prime Blend will immediately fail at Test#2 in less than two mins.
After I change NB Reference voltage from x61 to x67 and the rest of the remaining configuration left the same, I can immediately Prime Blend stable for several loops.
So now out of curiousity, I say why not try the x8 multiplier route again for maximum RAM OC using 4:5 divider. Keeping the same current CPU clock speed.
So...I was WRONG about the instability using x8 multimplier to OC the CPU w/ P5K-Dlx. Now I really gotta thank my P5K-Dlx for what it can deliver....I'm 100% SOLD !
30mins + and counting (I really have a good feeling about this cos I was having tough luck even at FSB460*8 and not even Prime-able for a couple mins); next goal: FSB470 & DDR2-1175 !
http://img505.imageshack.us/img505/3...table11qf1.jpg
Still using the same Vcore, I'm afraid I'll have to bump the Vcore by one notch.
But nevertheless, the mobo is completely happy with the Q6600 G0 at FSB470 and this is something that was not possible :)
http://img255.imageshack.us/img255/6...21175przm8.jpg
