works perfectly with my p5k
How are Asus motherboards; any cold boot issues?
any results yet?? :D
I have also seen some older ram not working in my board, like my XMS Pro with LED.
Voltage damper does work, droop is elimintaed.
Restart problem for phase change users still exist on Asus boards.
With stock NB sink my board is topping out at 550FSB
http://valid.x86-secret.com/show_oc.php?id=199837
Thanks info guys
I dont suppose anyones got the Asus P5K Deluxe with OCZ 9200 Reapers? would like to see if it's compatable. . . .
So is the P35 better than 975X? or worth the upgrade/change now, or wait for new boards/chipsets to come out? From some reviews theyve said its 4-5% faster on DDR2, any input?
For quad cores the new chipsets are best, I am going back through DDR2 now.
I can set 1Ghz ram @ 500 FSB and 4-4-4-15 boost enabled, playing with cores and bus speeds now.
Just noticed two cores enabled on above shot, I will fix @ higher clock.
any links to these betas?
http://www.ixtremtek.com/forums/showthread.php?t=70
Just wondering if anyone has tested the raid performance. :confused:
lol you been funny or something? it's on that website link you posted above for the P5K Deluxe:- http://www.ixtremtek.com/ixtek/Hardw...eluxe-0307.ROM
Those are Anandtech results, not mine:
http://www.anandtech.com/cpuchipsets...oc.aspx?i=2991
SPI results are not that good, but gaming tests are.
