Good, bad, and ugly update.
Just playing with the new stuff now...accidentally fried my DMM, so I only have 12V and ~7V to test for now :rolleyes: Still fun to be back and testing fans though :)
New location from last time, so very, very different noise personality....old results will not be directly comparable....I WILL retest many of the fans however :)
Due to a WCG-inspired processor swap, the CPU temp comparison will also not be directly comparable (went from a Celeron D...GREAT for this purpose, not for WCG...to a Conroe). For various reasons actually....I'm considering flat out dropping the CPU temp test. Results were largely consistent with restricted CFM test and this test took freaking FOREVER (~1hr a fan for the first pass [some ~25% of the time, another 1hr 2nd pass was needed to verify/rectify data]). Near the end I could pull a test time down to ~30min after I got in a groove, but that was only because the Celly D was so forgiving with going passive on the TTBT. And I've also repurposed the thermal probe I was using for ambient temps....and the Conroe isn't nearly as flexible as the Celly D was for stability at high temps. So the long and short of it is that the CPU tests future are in jeopardy. Talk me in/out of it....I'm on the fence, leaning toward ditching them.
I've been playing with my three new fans, the Sharkoon, the FN121, the U1A, and the SHE Tri-blade.
1) the San Ace is just incredible, freaking incredible. At ~7V it preliminarily pushes more air quieter than the Sharkoon does at 12V. At 12V, it pushes ~115CFM, not the 103 that it's rated. I can't get it to drop to ambient noise levels....but that's okay considering it's a 115CFM fan, lol. Compared to the restested U1A, it pushes 1CFM more at 12V and at 1dBA lower. At 7V, it's 7CFM ahead and 1.5dBA quieter. FWIW, the U1A is getting extremely similar results to what it had before...and it was an 'All-Star' before too.
The Panaflo LH is old school to the max....old school noise, old school design....and old school performance :-/ At 12V, it's around 5.5dBA louder than the 7V San Ace, and pushes the same amount of air. Compared to the Sharkoon, it pushes ~1.5CFM less at 12V and 3.5dBA louder. The Sharkoon also fell victim to an approaching thunderstorm that increased ambients a lot :(...so that dBA data may be on the high side.
The Comair is the worst rated fan I have tested to date...they say it's a 102CFM fan, but I'm getting 129CFM out of it....but it's also loud. Quickly compared to the Delta SHE Tri-blade, it was a little louder.
The Silverstone FN121 is still putting up identical numbers from before....the Yate was in a case and I was too lazy to remove it, so no retest numbers on that yet. The Sharkoon is getting ever-so-slightly worse dBA numbers (for now...thunderstorm and one piece of electrical noise may have effected it)....but still better at 7V than the FN121 is at 12V.
Anyway, so yeah, a thunderstorm has rolled in so noise testing is useless....and CFM results compared to last time haven't changed even a tad on any of the fans.
