Lapping is the only way to fly :D
So If understood corectlly .. after lapping I have to clean booth sides of cpu with 100% alcool?
Been a little busy with a job.. lots of clients, weird issues and so forth...
So i will lap in next weekend... cause I still have temp problem... 42-43 under no load. I had an opportunity to check out this issue with Intel CPUs on several new machines I put together lately.. and u were correct, 90% of them are surfaced flawed... u can simple check without any instruments.. put a coller on, and then take it off, if imprint of the default termal paste is not perfect square shaped on top of CPU, u will have temp issues depending of size of imprint missing, in case of recent computer i did, it was 50% missing so , beacuse I couldn't lap it... i filled it with termal paste, to at least do some dmg control.
I will be contactin Intel manufactoring diretly, and also over importer company my firm is working with.. and tell u what they replied.. I am mainly interested if they would allow authorised personnel to do little laping in case of surface not being flat and causing temp issues.
