LOL, because quad-cores are selling like hot cakes.Quote:
same "B" rule applies to the 6400, and probably all the conroes. i've had 4 A cores and 1 B core, none of the A cores would do over 3.4 ghz stable, using 7x multi or 8x multi with lower fsb, nothing stable without high vcore and high temps. the B core does 500x7 on 1.33 vcore and low 30's idle, does 3.6 all day with higher vcore, still much lower than the A core. A core wouldn't even do 3.6 stable at all. all were tried on DS3 rev 1, P5N-E, and P5B-Dlx, so wasn't a motherboard difference issue, and all ram was patriot ddr800. B cores rule!
complete nonsense ;) ... its nothing but luck if you get a good c2d !
btw ive made totally contrary experince. all my A's clock decent. only my """l628B""" was prettey bad. 3,6 ghz only at 1,62 v primstable.
well just tot i'd contribute too~
User Name: NightRaven
Stability: 13 Hours Orthos Blend Priority 4
CPU name: E6600
OC: 3802mhz
Stepping: 6 B2
Week: L629
Code: F050
Vcore: 1.775 bios set. 1.65 idle 1.6V load
Cooling: Water CPU + GPU
Cooler brand/model: Swiftech Apogee - in siggy
Motherboard: Asus Striker Extreme
Bios Version: 0402
Operating System: XP Pro Sp2
RAM brand: Crucial
RAM rated speed: PC5300
RAM actual speed: 846
Latency: 4-3-3-4
Here are the pics!
3.8 Orthos 13 hours blend priority 4
http://img397.imageshack.us/img397/1...mblend2ni2.jpg
Yet another update, this chips turns out to be a pretty good one: :)
User name: Zeus
Stability: 9+hours Orthos small ftt's prio 5
Cpu name: E6600
OC: 3850MHz
Stepping 6 B2
Week: L632
Code: A898
Vcore: 1.575V set in bios ~1.57V real (Vdroopmodded)
Cooling: water
Cooler: storm G4 - Thermochill PA120.2 - laing DDC+ w/ Petra's top
Mobo: Asus P5W DH deLuxe
Bios: 1503
OS: Win XP SP 2 32 bit
Ram: Gskill HZ 2x 1GB
Ram ratio: 6400
Ram actual speed DDR856
Latency: 4-4-4-12 (2.3V)
Validation:http://valid.x86-secret.com/show_oc.php?id=163920
yeah, well look at grim's results table. just about all "B" chips, no matter the model. add my B as well even though i didn't make the list cause i messed up. i also noticed that in bios, the voltage id of the A chips is 1.3xx, and the B chip is 1.2xx. there is a definite physical difference between them, and B's are better. i'm not saying that A's are terrible or not worth oc'ing, i'm just saying the B's are better in speed and vcore, and as a result temps.Quote:
Originally Posted by BAR*B*Q
You might want to check Grim's list again, for example, look at the 6600's.Quote:
Originally Posted by burn what?
Out of the first 10, 8 of them are "A" chips. :fact:
This "B" chip theory might hold some truth for older Conroe's, looking Grim's list i see some excellent results with "A" chips, my own chip included.
yeah, i suppose it might not hold water, from my own experience i found the B to be much better than any of the 4 A's though.Quote:
Originally Posted by Zeus
Are E4300 overclocks going to be added to the list??
I would love to see what weeks are turning out to be above average or below average :)
User Name: Nmbr1Ballr
Stability: Orthos 9+ hours small fft stable
CPU name: E6600
OC: 3603MHz
Stepping: 6 B2
Week: L631
Code: A966
Vcore: 1.5375 bios vcore (1.49 in windows)
Cooling: Air
Cooler brand/model: Scythe Infinity with Silverstone fan
Motherboard: Asus P5W DH Deluxe
Bios Version: 1506
Operating System: XP 32
RAM brand: Super Talent
RAM rated speed: PC6400
RAM actual speed: 800
Latency: 4-4-3-8
http://i116.photobucket.com/albums/o...letiszak/3.jpg
I'm the only one clocked at 3.6ghz that my cpu needed more that 1.5volts to be stable :(
Total agreement and not just because I have an A chip. :p:Quote:
Some guys claim that the number behind the A or B is more important than the letter with a larger number being more desirable. I say that is nonsense too.
My A886 chip runs 3.2 stable and cool on air at default voltage so regardless of it's letter I would classify it as a good overclocker.
:toast:
This is not the best I've had this system but it is the best I can get it now due to some very strange BIOS issues. It is a solid 12Hr test though and its not the worst entry so here ya go.
CPU name E6600
OC: 3240MHz
Stepping: 6 B2
Week: L631
Code: B120
Vcore: 1.36
Cooling: Air
Cooler brand/model: Tuniq Tower 120
Motherboard: Asus P5N32-E SLI
Bios Version: 0302
Operating System: XP-PRO 32
RAM brand: Crucial Ballistix
RAM actual speed: 432MHz
Latency: 4-4-4-10-2T
Need more info? look down.
GrimReaper do you update the list ? i can't see my results in list ?
http://img211.imageshack.us/img211/5...4135020xf6.png
User Name: tommrussell
Stability: 8 hrs orthos
CPU name E 6600
OC: 3510
Stepping: 6 B2
Week: L 632
Code: A 398
Vcore: 1.462
Cooling: Water
Cooler brand/model: D-Tek fuZion
Motherboard: EVGA 680 i
Bios Version: P-23
Operating System XP home 32bit
RAM brand: Corsair
RAM actual speed: 840
Latency: 4-4-4-12
EDIT : to correct ram speed
OK, I'm giving it one last shot.
User Name: handle
Stability: Otrhos 14+, 32m stable
CPU name E6300
OC: 3500MHz
Stepping: 6 B2
Week: L624
Code: A954
Vcore: 1.424
Cooling: Water
Cooler brand/model: DD maze I
Motherboard: Asus P5B Deluxe
Bios Version: 711
RAM brand: Crucial
RAM rated speed: PC8000
RAM actual speed: 1000
Latency: 4-4-4-12
cpuz link
http://valid.x86-secret.com/show_oc?id=164874
Screenshot
Another 4.2 GHZ Entry.
Username: Yoxxy
Stability: Orthos 8+ Hours
Cpu Name: X6800
OC: 4,207 MHZ
Stepping: 6 B2
Week: L626
Code: A851
Vcore: 1.60 droop to 1.58v
Cooling: Jinu Modded VapoLS
Motherboard: P5N32-E SLI
Bios Version: 0302
Ram Brand: Corsair
Ram Rated Speed: PC2-8888
Ram Actual Speed: 8896
Latency: 4-4-3-5
http://img77.imageshack.us/img77/3931/stabilitytc8.jpg
Kind of crappy as I can raise fsb and lower multiplier (425x10) and use ramspeed of 1160 which is stable and get worse performance. The next divider for me on this multiplier runs ramspeed at around 1180 which it will only pass orthos for 3 hours. I can run the 12x multiplier cpu speed of 4.26 and ramspeed of 1150 but that actually nets lower performance (I think it is fsb starved).
Sorry for asking,but why not a cpuz on that pic also?Quote:
Originally Posted by NightRaven
Still testing..... Im running orthos as im posting this at 3906mhz and downloading 3dmark05, so far its still a GO after 1hr :)
CPU: E6600
OC: 3825mhz
Stepping: 6 B2
Week: L632
code: B173
Vcore:1.57v ( 1.67 bios )
Cooling: Air
Brand: Thermalright Ultra 120 / 120mm circuit test 121cfm
Mobo: Asus Commando
Bios ????? ( came with board )
OS: XP
Ram: OCZ platinum XTC
Vdimm 2.1v
Speed: 425mhz
timing 5-5-5-15
Test Othos 8hrs...
http://www3.telus.net/luis99/orthos@3825.JPG
Hope this is just for benchmarking and not a 24/7 setup. Your temperatures are basically 70ºC and thats using the asus temp. which we all know reads lower than TAT or Coretemp.Quote:
Originally Posted by luihed
I just got the chip and burning her in...... 24/7 Ill prolly drop it down to 1.6v ( bios ) and 3700mhz, she wont be as hot ....... right now vcore is set at 1.735v
keep up the good work!
Superpi 32M finished @ 4006mhz...... still on air:D
http://www3.telus.net/luis99/superpi@4gs.JPG
Right now I think I have hit a wall. I am at 3.6ghz @ 1.5375volts in bios. Temps are at 57ºC at load. I try and run 3.8ghz @ 1.65volts and it gets to the point where normally that windows screen would come up where the blue bar goes across the bottom of your screen a couple times, but it just sits there at a black screen. I do have an A chip also. Any ideas? Also if I want to run my ram faster and in bios it lets me choose from 800mhz next is 1000mhz, what if I want like 850 or 900? Can I do that and how?
I cant help you on the first question as there are so many things that can be the cause of your oc wall...... as for ram overclocking, your rams are being overclocked when you overclock your cpu's fsb, so to get 850, set your fsb to 425 ( assuming youre running 1:1 ) 900 on the ram is 450fsb.....
I am 1:1 right now, but what if I wanted to be like 4:5 or something. Say I want to leave my fsb @ 400 but OC my ram to 900. In bios it only lets me go to 800 then 1000 then up from there.Quote:
