And then some...:DQuote:
Almost into the 10's. With 1.7v, it would be a done deal.
http://img122.imageshack.us/img122/1006/4653gd3.jpg
Hexus Pifast. Still 1.65v:)
http://img422.imageshack.us/img422/27/pifast2053ci7.jpg
Originally Posted by sierra_bound
Nice...
Do you know how to volt mod either with pencil or POT these boards?
I really want to try and hit 4.5 for benching...
AndreYang has a pic showing the OVP mod. Without this mod, you won't get more VCore.
http://www.xtremesystems.org/forums/...&postcount=261
VR-Zone has Vmem and VMCH pencil mods
http://www.vr-zone.com/index.php?i=4060
[QUOTE=sierra_bound]AndreYang has a pic showing the OVP mod. Without this mod, you won't get more VCore.
QUOTE]
You rock thanks!!
Hey cant that resitor be penciled to decrease the resistance?
Or bypassed with an adjustable 10k pot ... hmm does that 5K mean it needs a 5k pot?
I got this version last week.
It is BY FAR the best C2D motherboard I have tried.
I previously tested the P5B-D, DH, P5WG2-WS Pro and an ABIT A89.
This one is superior, by a large margin.
Andrew
Originally Posted by Dumo
I will be RMAing this board for a refund tomorrow... yes it will hit 460 fsb at 1.8vMCH but it would not hit 470. It also has the same vDroop problem as my P5W Delux 68xxx version. I simply need a vcore that delivers as advertized to go any higher.
--edit-- I have the same one as you...aamsel ;)
What multiplier did you hit 460 with, that won't hit 470?
Are you sure that this motherboard is limiting your o/c?
Yes, they overvolt this board to compensate for vDroop, but it is IMHO very stable, at least the one I have is. With about 4 E6600's I have tried, I had not hit above 385 with any C2D mobo with standard 9X multiplier. With this P5W64 I hit 400 without a problem. However, 3600MHz is about "all she wrote" for my current week 28 chip at 9X (or any multiplier below that).
Andrew
Originally Posted by sdumper
ROFL :D Well, I am persistent as well. Still @ 1.648VQuote:
I think I might be able to squeeze into the 10's with 1.70V although I'm not as close as sierra_bound :p:
Here...http://www.xtremesystems.org/forums/...&postcount=135Quote:
@Sierra....Nice B2 there:toast: Definitely 5G with LN2.
I hit 460 wall too on my 6400 no matter how much vmch i put.. vmod to run at 2.0-2.1 still cant go higher. Worst anything higher than 1.95v, i will got failed overclock from startup.
Mobo didn't post over 1,95V Vmch - You must boot @ 1,90-1,95 and go higher when running :DQuote:
Originally Posted by rithina
Boot with high fsb and go with clockgen ...
I have another issue with this mobo...but nothing to concern about (I hope) ;) I have set the VCORE in BIOS to 1.400v and clocked to 3.5ghz....CPUz and ather windows tools shows 1.45V...than I have set VCORE to 1.375V and CPUz shows 1.424V...but when I clocked my C2D to 3.4ghz with VCORE 1.400V CPUz shows 1.380V...:confused:
Regards,
Primoz
Originally Posted by aamsel
where did you buy yours, andrew?
gosh!...i would be delighted with 460 FSB!...i can't get over 375 FSB at 10x or 400 at 9x (same at lower multi's) with my retail E6700 on the P5WDG2 WS pro board.Quote:
I also have an e6600 week 27 and an e6700 which I will try.Quote:
I attempted 470 at a multi of x6 ;) NOTE: Bios 0215.
Maybe its just the x6800 running into problems also note that I did not remove the stock chipset passive cooling yet. I will be trying some other configs out this weekend and adding better chipset cooling... dont get me wrong the board is very good but I have now purchased the following:
1 - P5B Deluxe
1 - P5W Deluxe (vMch 1.65)
1 - P5W Deluxe (vMCH 1.85)
1 - P5W64 Pro (vMCH 1.8)
and from what I am seeing so far the best mobo if modded for vDroop is the P5B Deluxe with that board I had no problem at all with the higher FSB's but I was limited with by the vDroop.
I tried almost all of 'em, and I like this one:) .......http://www.xtremesystems.org/forums/...8&postcount=10
ewiz.
Andrew
Originally Posted by Ace-a-Rue
I am confused now, I thought you HAD a P5W64Pro since you were replying in this thread???
Andrew
I have all of the boards that I listed ;)Quote:
And I am so far not happy with the P5W64Pro as I mentioned I bought this board expecting big things. I also went on to say that I would try different chips in the P5W64Pro over the weekend to see if I have any better results. Who knows maybe I am just hitting the limits of my particular x6800.
This was my best run:
http://sdumper1.smugmug.com/gallery/1946020/1/100429431
http://www.overclock.net/benchmarkin...-times-16.html
@sdumper
Have you tried using 11 multiplier instead of 10? I think x11 with 4:5 ratio will give you very good results.
With 460-470FSB, you are pretty much forced to run 1:1 with this board. The boost you get in memory speed at 4:5 will make up for lower FSB.
Ill give it a try tonight ... my Chilly is acting up a bit to so my temps may be a tad higher than needed. Hopefully my modded Mach II will be ready soon and temps wont be a concern anymore.Quote:
I got a new one to torture....Quote:
http://img171.imageshack.us/img171/8...shot001eg9.jpg
Why do you buy so many 975x mobos?:eek:
Most of them have short life with phase. I am testing a newly repaired cascade with better insulation on 975X mobo.
Cascade still needs tuning for better load delta temps.
http://img147.imageshack.us/img147/8...shot003jn8.jpg
