Originally Posted by linflas
I have my X-Fi in a pci-x slot with no problems. What was yours doing?
what's the bus speed set to on the PCIx bus?
the x-fi card runs problem free in pcix,jumper at defualt auto-select position
hmmmmmmm....2 out of 3 say its ok...what is wrong with you, linflas!:D
guess I just got unlucky, had a microphone glitch through the front panel of my platinum, could not make it work, a slot switch fixed it, not sure if I was just being lazy, and did not trouble shoot, was weeks ago now
don't feel like swapping cards now, as I am too lazy
everything works great now, so, as usual, will leave well enough alone :)
There's one other thing about those pci-x slots, not all pci cards will fit... My X-Plosion sound card doesn't have the tab cut-out and won't fit in there.
Saw this on another forum, anyone have any idea what it is for?Quote:
There is a Windows Hotfix for dual core cpu's (SP2), to make them work more reliably (microsoft hasn't publicly made this file available for download so here is some links to it; http://www.amdzone.com/files/WinXPdualcorehotfix.exe
Exited a new bios?
By:)
from what I read this helps address the problem of amd dual core not having syncronized core speed among the cores,so by defualt xp will tend to put all load on one core
many people do not realize that Intel and Microsoft have worked closely together over the years on improving their operating systems.
Originally Posted by dj883u2
huh?
I asked if it were exited a new Bios.Quote:
Originally Posted by xgman
By:)
I have to ask, what sort of FSB are you guys with 4Mb cache CPU's hitting? I'm finding it real hard to break 441MHz regardless of multi, is there some setting or trick to this?
I just run 4-5 at 400+/500+Quote:
Originally Posted by HermS
hmmm yeah me too, 400/500 nice and cool running for 24/7. I just want to be able to get up above 445 so I can break 4GHz.
The stable maximum of FSB for my card motherbord to air is:
http://img427.imageshack.us/img427/5...soreol2.th.jpg
http://img231.imageshack.us/img231/912/ramto3.th.jpg
By:)
Very nice, what VCore, VMCH and VFSB to reach that speed?Quote:
V.core 1.52VQuote:
VMCH 1.8V
VFSB Auto.
By:)
What is the best bios for high FSB?
Originally Posted by fishingeek
in which pci-x ?
first or second?
i'd like an answer on that tooQuote:
Originally Posted by Pansu
i guess we all need a new bios that would loosen things a little bit...
i'm getting tired of not being able to run various ram kits
not even at their default timmings (manually set..)
@#$% auto setting sets everything @ 5-6-6-18....
0408 or 0005 both work fine for the ram, try them first, stay away from 0502, it is unstable
indeed 502 seemed less stable than the others.. :up:Quote:
but i've also tried 005
and currently i'm using 0408...
keep in mind that i'm talking about orthos & SnM ram related stability issues
and not just a quick Spi1M run....
Second. No problems yet.Quote:
Originally Posted by arne72
Geek
I tried a PCI NIC in the bottom PCI-X slot last night and it worked for a few minutes but would eventually lock the PC. I keep getting network dropouts from the onboard ethernet.
