Here not works.. Max is 1.65 :(Quote:
Originally Posted by M3kk
my max is still 1.65 as well.
have you both cleared cmos yet?
Yes.. just flashed with afudos, same sh it, max is 1.65 :/
yes that would be nice. maybe Bigtoe (Tony) at OCZ could mod it for us. he is very good at that.
Do the unplug, remove battery jumper on clr for 30 sec. replug everything , reasave cmos, then check again. :confused:Quote:
my max is still at 1.65 also :(
Oh well, now I have the board out I'll do the Vmod too ;)Quote:
Originally Posted by nop
Done but without any positive result..Quote:
Originally Posted by xgman
Damn, now its Vmod time ;)
I am guessing that IF the 1.85v has worked for some, that the voltage controller for the vmch is somehow a different rev hardware version than that on the boards above that still only see 1.65v.
Originally Posted by hot_fifty
What works? You now have Vmch options to 1.85V? can you take a screenshot?
Originally Posted by VL125
From this pic of the pencil mod, I'm not sure where the red line leads to exactly. Anyone know more precisely what points on this pic are suposed to be penciled?
http://resources.vr-zone.com.sg/Sham...whpencil/2.jpg
Its soldered at both ends, you need to make a graphite path from one end (of the solder), across the top to the other bit of solder. And don't blow any graphite dust on the board, not a good idea.Quote:
when are the voltmods coming
also, to the people that are afraid to hot flash, u can request a bios chip from asus... be sure to include the model and serial number
its free and free ground shipping
if u want next day shipping, include the credit card number
edit: found a pencil mod http://vr-zone.com/index.php?i=3876
edit2: heres a more detailed thing, just fill in the needed stuff and copy to a mail... DONT COPY THE STUFF IN THE **
rma@asus.com
- "The motherboard does not work as advertised without a newer BIOS than what it shipped with. I need a newer BIOS revision to work with my Intel Core 2 Duo processor. I do not have a spare processor to flash the BIOS with. Please send me a new BIOS chip with revision 0801 or newer using the information below. Thanks in advance."*
- name
- street address
- phone number
- model number & serial number
- ground(free) or overnight($20)**
*supposedly 0801 is compatible with ALL Core 2 Duo processors, but if you want the beta revision 0901 (as of 8/9/06), specify that here
**for overnight, give them your credit card info as well (account number, expiration date, and CSV)
My pencil mod works well on mch. I used 2B pencil, and up to 1,77v.Quote:
Originally Posted by fornowagain
Will next vdimm..
Hello all
anybody know where we can find bios 1101 because i have an X6800 retail B2 and of course on the P5W-dh it doesn't work, not found any links on asus site. Maybe on asus FTP ?
rma@asus.com
- name
- street address
- phone number
dont copy the asteriks into the email
its safer than hot flashing becuase u dont have the chance of burning ur mobo
ok found !! on others posts on this forum. thanks
So if I take off this...
http://gallery.weyland.be/d/9803-2/DSC02399.JPG
Its not a good idea to take the gunk of it? becuase if you apply AS/thermal gunk it wont fit again?
Can I take it off and apply Arctic Silver 5 to the chip on the NB and re-use thise on the radiator thing?
Im sure when I done the Southbridge it was on firmer and thats why it seems a bit loser? should I apply thicker amounts?
EDIT:
Gonna leave the gunk on the mossfets cos they dont get to hot, but i'll apply thicker amount to the nb/sb heatsinks.. oh and lose those gay covers too.
Well I just done it all and Im very pleased to announce my temps are now 40c motherboard and 29c cpu. Muuuch better than 54c board, thanks for the guide.
Edit:
Oh screw it I spoke to soon, the temp has gone in to the red again with pc probe...
Whats a good temp to set pc probe alarm at for the motherboard temp?
It gets to 45c and goes into the red and gives me warnings.
Its at 51c now... christ I give up.
Can someone tell me what causes the heat, the south or northbridge?
And is that temp a combined reading ie 50c = 25c N and 25c S bridges??
Mobo temp is related to southbridge but northbridge is the hottestQuote:
Originally Posted by Jimbo
You also can replace the stock HS as I did
http://img71.imageshack.us/img71/8096/dscn2262hv1.jpg
how did you attach you heatsink, I am thinking about clipping the asus cooler, leaving the power cooling part of the system with the included fan and adding a water block to the northbridge, just have not seen a good way to connect it, as I will not be on a bench, but in a case.
So need to hold it down, was thinking of using arctic silver ceramique, the heat epoxy stuff I used on the ram sinks for my video card, any other ideas out there?
this NB cooler is chip with retention clips which fit perfectly over the P5w dh NB :)
it is the coolermaster "blue ice" ( didn't want to wait for extreme spirit 2 )
