PixelView GF4 Ti4200 - 128mb
I have PixelView GF4 Ti4200 - 128mb, the VGA has two SC2602S IC regulators and Samsung TC40 modules. OK ... I did the mod to pin11 with 1Kohm for both IC. Cooling is no problem here, Big Ram Sink are employed.
Now my question: How come I see NO BIG performance difference in DDR speed after the mod? The memory speed stuck at 550MHz (default) and at 570MHz (with 1Kohm). Even some artifacts can be seen at 570MHz (with 1Kohm).
Can someone give me some tips?
Memory Mod For GF4 Ti4200 with AGP 8X
People.... please help me. I want to volt mod VGA's memory, but mine is little bit different than the first generation of GF4 - 4200(NV25).
Mine is GF4 with AGP 8X (NV28), look at the pic and help me how to volt mod the memory. The IC for memory voltage regulator is ACOA 0236.
Lastly... I use 1K ohm for CS2602S, and the screen go blank instantly. So I removed the resistor and the VGA is okay. Should I use bigger resistor such as 2K ohm ?
http://www.ixbt.com/video2/images/re...-scan-back.jpg
