high multipliers with an old motherboard?
ok, i've got a MSI K7T Turbo LE motherboard and an XP1800 T-Bred "A". the motherboard has a KT133A chipset, and the multipliers in the BIOS go up to 15x.
anyway, the multipliers above 12x don't work correctly. i can get 12.5x by selecting the 13x multipiler, and the 14x and 15x ones give me some strange low number.
so, if i cut the correct L3 bridge on my XP, what is my motherboard going to do? will it work with the higher multipliers?
normally i'd just jump right in and start cutting bridges, but i can't afford any new parts right now, so i've got to be careful.
Re: high multipliers with an old motherboard?
http://www.beachlink.com/candjac/index.htm link to Workarounds article, has ideas on accessing high range of Multiplier. See how you feel about them. Going from low range to high range are untested.
If you don't like them, then you might consider hard modding the L3s. There's a Table of Bridge Settings in the Tbred article...look it over to see which you'd have to open and close to set what you want.
John C.
