DelRez Gets a Blinged Out Brother
Heh, this part is just simply gorgeous if I don't say so myself! Made these on a whim, just picked them up from the machinist yesterday. Actually I just took one, the other 3 are being properly polished on the inside, you will see this one is not... This part was made and designed by me, you can refer to this thread for details: http://www.xtremesystems.org/forums/...ad.php?t=88333
This part here is made from a solid cylindrical 3" diameter piece of CAST Acrylic. The piece is solid, nothing is glued together, barbs, plugs and fill glass are all o-ring sealed. Thread size is G 1/4" (BSPP Parallel thread). Enjoy, and just imaging the inside polished.
Please don't ask for this, it is acrylic and needs to be tested for integrity. Any beta testers around? :D
http://www.anonforums.com/builds/del...ylic/mount.jpg
http://www.anonforums.com/builds/del...lic/mount2.jpg
http://www.anonforums.com/builds/del...lic/mount3.jpg
http://www.anonforums.com/builds/del...lic/mount4.jpg
http://www.anonforums.com/builds/del...lic/mount5.jpg
http://www.anonforums.com/builds/del...lic/mount6.jpg
Ready for the bling?
http://www.anonforums.com/builds/del...htnomount3.jpg
http://www.anonforums.com/builds/del...htnomount2.jpg
http://www.anonforums.com/builds/del...ghtnomount.jpg
http://www.anonforums.com/builds/del...ightmount2.jpg
