Hi,
i´m searching for the highest prime stable overclocked a64 3000+
i havent found yet a cpu which runs higher than mine :P
do you know somebody which runs better? :slapass: :cool:
http://www.forumdeluxx.de/gallery/da...me_3_4_ghz.JPG
Hi,
wow...
Only aircooled here, so no way i can beat that :P In a Mach2 i know someone that runs 3200 prime stable... But yet far from you...
Beautiful. What is the stepping on that one? It would have to be one of the best.. 0517EPMW, 0521DPMW?
its a 0520EPMW
that is amazing
how far does it ss
this one goes to ~3,59 ghz.my other 3000+ went to 3620 mhz without hs, but the cpu´s dead ^^. ( i think i would have broken the actual wr if the cpu didnt end up in smoke :P ) . the 3000+ which is still alive is already sold , because i needed money for my 950es which arrived a few days ago
Very impressive chip you've there :clap:
Wow really nice CPU, 0520EPMW are mostly very creep . ;)Quote:
Originally Posted by Xtasy
Mine 0517 EPAW , WITH IHS (never remove)
http://www.members.lycos.co.uk/piotr.../3321prime.JPG
3321 Mhz SP2004 stable
http://valid.x86-secret.com/show_oc?id=53575
3528 Mhz validation, No 5 @ the World (CPU-Z database, except 2 fake scores)
CPU has died 4 mounts ago ...0517EPAW I miss You :(
Regards
Peter
Damn :( Mine's a LBBLE 0522VPMW and must be the worst Venice in the World... I'm almost sure i had a 0517 in my hand when i bought this one...
I know the guy that bought it and does 2850 @ 1.55 prime stable... Mine doesn't even do 2700 Prime stable @ 1.6... All aircooled course...
Wow that's sadQuote:
Originally Posted by God_Lx
Mine 0517 EPAW had been doing 2880 Mhz/1.52V prime stable on air :)
piotres probably it's just like the one i had in my hand :( And the worst part is that he's using the CPU @ default... :(
I always loved this CPU even I lost all competitions against it with my poor venice 3200+ :D xtasy teh rock'n roll :cheer:
A good chip at stock speeds, that should be illegal. I wonder how long that Venice will live at 1.84V.Quote:
well gave only 1,84 v to test which clocks are primestable. normally it runs @ 1,72 @ 3,2 ghz
Wow Nice jobs Man !!!!!
that was my other 3000+ without hs running under my mach 2 gt with 3620 mhz picstable. ^^
http://www.forumdeluxx.de/gallery/da...2164bx-med.jpg
Nice!:up:
I assume that happened because of condensation? ;)Quote:
well i think not, because it was well isolated.further i think that there was a problem with the vcore, because the power pins are burned. the evo o my mach 2 gt is modded so using a cpu without hs ist absolutly no problem.
its funny, in luxembourg i´m the oc champion because here´s nobody ,exept me ,who is using a single stage or something other extrem to cool down :P
http://www.forumdeluxx.de/gallery/da...0_1179-med.JPG
http://www.forumdeluxx.de/gallery/da...2096or-med.jpg
http://www.forumdeluxx.de/gallery/da...1951sq-med.jpg
http://www.forumdeluxx.de/gallery/da...1811hv-med.jpg
the benching rig:
http://www.forumdeluxx.de/gallery/da...ld_002-med.jpg
http://www.forumdeluxx.de/gallery/da...0_1205-med.JPG
The WR goes to Luxembourg :P !!!
Never seen a venice 3000+ @ that high primestable, Nice :toast:
What is highest bench frequency?
well i didnt try it out because its to much on vcore. i testet a little bit with super pi @ 3339 mhz @ 1,72vc (prime stable) and reached 25,750 sec. if i wouldnt need the money i would give the cpu 2 v and try to get 4 ghz :P
Awesome work Xtasy :clap: :bows:
Too bad we won't see a 4Ghz attempt but I can hear that 950es screaming allready :slapass:
I like that CAS too btw :fact:
Greetings from Germany ;)
that's the same as my 3500... which primes at 10x292=2.92GHz on air (naked) on my Ultra-D... i'd say it's a good stepping! :toast:Quote:
This is the chip that reached ~3.7Ghz on dice when I tested it :)
Prime @ 3.4Ghz but I guess 50Mhz more would be possible with some tweaking and probably more volts
http://www.xtremesystems.org/forums/...9&postcount=23
