What are some stable timings to use with this kit of memory? They don't have to be the most aggressive... just stable. I can not get this memory to run in my Abit KN8 Ultra without random restarts/BSOD's. Only trying to run the memory at 278.
well could you please let me what what is bios setting option on abit mobo
from there i can help you more
No problem...
Tcl
Trc
Trfc
Tras
Trcd
Trrd
Twr
Twtr
Trtw
Command Rate
Read Preamble
Bank Interleaving
Burst Length
Drive Strength
R/W Queue Bypass Counter
Bypass Max
Idle Cycle Limit
MTRR Mapping
32bit DRAM hole
The board does not have adjustable Tref... I have been suspecting this might be the problem? A64 Tweaker detects Tref as 200MHz 3.6us when I am running the ram 1:1 @ 278.
Tcl = auto
Trc = 7~9
Trfc =13~18
Tras = 7
Trcd = 4
Trrd = 2
Twr = auto
Twtr = 1~2
Trtw = 2~3
Command Rate = 1T
Read Preamble = auto
Bank Interleaving = enable
Burst Length = auto
Drive Strength = auto
R/W Queue Bypass Counter = auto
Bypass Max = auto
Idle Cycle Limit = 256
MTRR Mapping = disable
32bit DRAM hole = auto
some of then i am not sure, i suggest you set at auto and see how is it!
Will give it a try tonight. Thanks for your help. :up:
let me know cuz i never try Abit b4
Seems to work. No problems yet. The real test starts tonight when I turn Rosetta@Home back on.
http://www.cas.uc.edu/~smithmd/gskill.JPG
I set the Idle Cycle Limit to 256 in the BIOS, but it detects as 16 in CPUZ and A64 Tweaker :shrug:
Thanks again for your help. :toast:
Looks like my system restarted 3 times during the night running Rosetta. Still have some work to do.... :(
check does other hardware holding it. looks like no memory problem
Don't know what else it could be? CPU is running at 2.5GHz as it has without problems for 9 months. HTT is down to 278 now from 313 where it was stable for 2 months that I have had this Abit.
What voltage would you suggest for 278MHz? I was running 2.7V.
i think 2.7v is good. hummQuote:
Originally Posted by shmaa
try something like 3D test...
run the Rosetta and see how long will it takes to crash
