Tyrou's Tri-Vap 402
:wave:
Here is my last single stage, I made it for a guy on a french forum, he wanted to cool his whole rig, one cpu, and two 7800GTX in SLI, so I decided to make to separate systems, one for the cpu, and the other for both gpus...
The original goal was -45C on the cpu evap and -35 on both gpu evaps, with no load, no suspense here, we broke that :D
Compressors are 1/3HP, I also used cap tube on this one, and the systems are filled with R402A
GPU evaps are made with a CNC mill, what's nice is the whistle they produce when the R402 boils in them, that's how I tuned the dual evap...
The cpu evap is more classical, homemade, but quite efficient, and should hold a load easily.
Condenser was modded to receive the two systems and has 4 120mm fans on it. No shroud due to the lack of space...
The case is made out of MDF, I don't know if this can be called "wood", but it's great to absorb noise and vibrations. I painted it with a aluminium-looking spray, pictures are not looking good due to the shiny effect of this paint, actually, it's not as bad as it looks on the pics :D
Now, let's go for the pics :slobber: :
http://www.tyrou.net/Phase-Change/Tr.../Trivap-08.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-09.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-10.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-07.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-11.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-12.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-13.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-14.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-15.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-16.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-17.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-18.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-19.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-20.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-21.JPG
Temperatures (°C)
Cpu evap :
http://www.tyrou.net/Phase-Change/Tr.../Trivap-02.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-03.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-04.JPG
Gpu evaps :
http://www.tyrou.net/Phase-Change/Tr.../Trivap-05.JPG
http://www.tyrou.net/Phase-Change/Tr.../Trivap-06.JPG
Please keep in mind that's with no load, but I hope to get -40 loaded on the cpu evap, and -30 on the gpus.
Original thread here (Cooling-Masters.com - french forum) : http://www.cooling-masters.com/forum...=0#entry153757
:banana:
WoOt my friend, another pretty nice system :banana:
pretty nice? That's amazing. I like the 2 gpu evaps 1 hose design. Are they rigid at that distance apart from each other or can you adjust them to differenct distances?
amazing temps too, -50C for GPU
And nearly -70c for the cpu...
nice & clean build there. Great temps to!
so you have 2 compressors sharing the 1 condenser?
C-BuZz
i have seen your build somewhere else.. and not that forum you posted a link to here... but it had a picture of how you used 1 condensor for 2 stages
You cut into the condensor and brazed it so its actually 2 condensors right?
:toast:
the gpu evaps are 6cm away from each other, but as I made a copper loop between them, it's adjustable, I'd say from 35 to 80mm...
the two compressors are sharing a condenser, but actually it's more like two condensers, I splitted the one I had in two separate circuits
martie, the system you must be takling about is my cascade, I cut a huge condenser in half, then re-brazed them together to make it more compact ;)
For sure, it won't hold any load at -68, but I re-tuned it for a -40C loaded if everything goes well :)
Nice unit... 24/7 now is fun! haha great!
my friend that's marvellous!
look how that this is compact
:toast:
it measures 60*30*32 cm, that's quite compact, but heavy :)
this is made for a 24/7 use, so I turned the fans to make them blow on the compressors, I don't want them to overheat in that box
:cool: You think about everthing :D
Really nice work ...
Some questions : :)
1. Have You brazed the evaps in gas shield ?
2. That -68*c on cpu evap was in what vac ?
3. What is the compressors manufacterer and model ??
Regards
Peter
thanks piotr :)
brazed with CO2 as a shield gas, I don't have nitrogen anymore
that -68C was only for fun, according to a P/T chart, that should be somewhere near 0.2bar abs.
compressors are Zem/Electrolux, GL99AA model, 1/3HP
