Anyone Try Corsairs 2 gig PC3500 LL Kit??
I have a set of this stuff burning in at the moment, doing 2.5-3-2-6-1T at 2.6 volts, running 11 x 225 so far.
it's been burning in in memtest 86 for the last 43 hours, on test 5.
this test apparantly runs the ram at max load, and does seem to heat up the ram pretty good.
measuring the temps, with my DT-200, I see it is at about 121 F to 125 F, and is pretty toasty to the touch, but it's still not given even a single error.
I am gonna give it another 2 days, before seeing if it does any better.
early tests I was able to run about 230 at cas 2-3-2-6-1T for about 2 hours, before it would error... that was with the default test though.
240 is the best I got so far from it, but thats at cas 3-3-2-8-1T.
this ram, is extremely finicky so far.
it takes almost nothing to make it crash, then get that one setting just right and Boom... another 5 mhz from it.
very very finicky ram so far.
in reviews I seen other people doing 260-270 with this exact ram, but I can't even do 250 with it, no matter what timing... but with how finicky it has been just getting 240 out of it, it really wouldn't suprise me, if it's just one little setting holding me back.
it did after all take alot of tweaking to find out where 240 was stable.
(2.8 volts, 3x LDT, 1.65 volts chipset, load optimized defaults, set only Cas, Ras to cas, TRD or TRP?, and Tras, then leave everything else alone, and then solid)
anyways, I am just curious to see if anyone else has given this ram a shot, and what you can do with it.
