ATI Avivo encoding + HIS X1800XT + Opteron 170 dual core
Xmas day and what better way than to play with new toys :D
Time to test out ATI's Avivo software with my 512MB HIS X1800XT on my Opteron 170 dual core cpu to see what's all the fuss about :)
Required software:
Source video files to work from:
Xbox HD video trailers:
http://www.microsoft.com/downloads/d...displaylang=en
- Call_of_Duty_2_E3_2005_Xbox_360_Video.wmv 93.2 MB
- Condemned_E3_2005_Xbox_360_Video.wmv 53.0 MB
- Dead_or_Alive_4_E3_2005_Xbox_360_Video.wmv 286.0 MB
- Dead_Rising_E3_2005_Xbox_360_Video.wmv 75.9 MB
- Demonik_E3_2005_Xbox_360_Video.wmv 61.5 MB
- EA_E3_2005_Xbox_360_Compilation_Video.wmv 93.5 MB
- Final_Fantasy_XI_E3_2005_Xbox_360_Video.wmv 79.5 MB
- Frame_City_Killer_E3_2005_Xbox_360_Video.wmv 78.8 MB
- Full_Auto_E3_2005_Xbox_360_Video.wmv 57.9 MB
- Gears_of_War_Xbox360_Video.wmv 102.3 MB
- Ghost_Recon_3_E3_2005_Xbox_360_Video.wmv 86.1 MB
- Kameo_E32005_Xbox_360_Video.wmv 84.0 MB
- Madden_NFL_06_E3_2005_Xbox_360_Video.wmv 49.2 MB
- NBA_2K6_E3_2005_Xbox_360_Video.wmv 68.1 MB
- NHL_2K6_E3_205_Xbox_360_Video.wmv 65.8 MB
- PGR3_E32005_Xbox360_Video.wmv 25.1 MB
- PGR3_Tokyo_Xbox_360 Video.wmv 68.1 MB
- QUAKE_4_E3_2005_Xbox_360_Video.wmv 127.8 MB
- Test_Drive_Unlimited_E3_2005_Video.wmv 89.9 MB
- The_Darkness_E3_2005_Xbox_360_Video.wmv 72.2 MB
- The_Elder_Scrolls_IV_Oblivion_E3_2005_Xbox_360_Vid eo.wmv 87.6 MB
System
Opteron 170 CCBWE 0546XPMW cooled by Corsair Hydrocool 200EX
DFI NF4 UT SLI-DR R.AB0 11/14-3 bios
512MB HIS X1800XT with Cat 5.13 drivers
4x 80GB Hitachi 7K80 SATAII Raid 0 OS drive
1x 250GB Maxtor Maxline Plus II PATA
Pioneer DVD Burner
Floppy drive
650W Silverstone SLI PSU
WinXP Pro SP2
NF4 6.53WHQL chipset drivers
DivX 6.1 codec
Using 2x 1GB OCZ PC4000EB Platinum 3-3-2-8 rated memory
Results
All conversions are done in the same windows session for each cpu speed clock i.e. 2000mhz, 2400mhz, 2600mhz and 2800mhz.
http://www.fileshosts.com/DFI/NF4_SL...ettings_tn.jpg
:: @10x200HTT = 2000mhz @200mhz 3-3-2-5 7-14-2223 ::
Source: Toyshop WMV file (91MB)
Settings: Highest quality
Output format: MPEG-4 DivX (56.9MB)
Conversion Time: 53 seconds
Source: T2 720P WMV file (92.5MB)
Output format: MPEG-4 DivX (33.5MB)
Conversion Time: 38 seconds
Source: Speed 1080P WMV file (128.2MB)
Output format: MPEG-4 DivX (54.2MB)
Conversion Time: 1m 12 seconds
Source: Taxi 3 1080P WMV file (161.9MB)
Output format: MPEG-4 DivX (41.4MB)
Conversion Time: 1m 14 seconds
:: @10x240HTT = 2400mhz @240mhz 3-3-2-5 7-14-2223 ::
Conversion Time: 44 seconds
Conversion Time: 43 seconds << weird repeated a few times and slower than @2000mhz ???
Conversion Time: 1m 00 seconds
Conversion Time: 1m 03 seconds
:: @10x260HTT = 2600mhz @260mhz 3-3-2-5 7-14-2223 ::
Conversion Time: 41 seconds
Notes:
- Well Dinos got the same conversion time with ATI X800 video card with Cat 5.12 drivers and the hacked Avivo video converter http://i4memory.com/showthread.php?p=31423#post31423 !
- X1800XT's benefit then not yet implemented by ATI ?????
Notes:
- Again Dinos with ATI X800, was 2 seconds faster http://i4memory.com/showthread.php?p=31426#post31426 ??
Conversion Time: 55 seconds
Notes:
- Same time as Dinos with ATI X800 http://i4memory.com/showthread.php?p=31427#post31427
Conversion Time: 57 seconds
Notes:
- My time was 2 seconds faster than Dinos with ATI X800 http://i4memory.com/showthread.php?p=31427#post31427
Could be related to Dinos' DivX codec version differences ?
:: @10x280HTT = 2800mhz @280mhz 3-3-2-5 7-14-2223 ::
Output format: MPEG-4 DivX (56.7MB) <- file 0.2MB smaller ?
Conversion Time: 40 seconds
Output format: MPEG-4 DivX (32.7MB) <- file 0.2MB smaller ?
Conversion Time: 40 seconds << weird repeated a few times and slower than @2000mhz but faster than at 2400mhz and 2600mhz ???
Conversion Time: 52 seconds
Judging by the times, maybe the source files aren't long enough to show a more accurate conversion time ?
Graph below displays the above results for easy viewing.
http://www.fileshosts.com/DFI/NF4_SL...0_image001.gif
It seems Avivo still needs a few improvements as the times between Dinos using ATI X800 with Cat 5.12 are really no different from the above results using ATI X1800XT with Cat 5.13. It maybe that the source files are too short and thus not as accurate ?
I believe ATI's current Avivo Xcode is CPU based only - so will have to wait for the future versions to take advantage of X1800XT GPU ?
Any suggestions for other tests ?
Update: Added List of Xbox HD video trailers you might want to try :)
