Max possible settings single XL + fear1.exe
http://www.xtremesystems.org/forums/...chmentid=39835
Post some SLI scores.
soft shadows on?
that is indeed a good question charles..
but it looks like that fear tweak did wonders for the XL...
Soft shadows was set to on.
alright!
i believe u, i get 2/3 the results w/ half the mhz :D
what was ur xl oced to?
what resolution did u set it to, and how? :confused:
1600x1200x32 in FEAR.
710/800 on machine below.
kohan here showed me that 1280x1024 is TOTALY playable with 4xAA , 16XFSAA with max settings using the fear1.exe mod.. pretty amazing..
btw he accomplished this on a 550/550 clocked 16pipe X800GTO, along with a 2.3ghz venice and some ubercraptacular ram.
whoa....what? im gonna have to try this with my 560/590 gto2 and my venice at 2.6
brb :D
well i cant really say that renaming the exe worked for me. what do you guys consider a playable framerate? if i go under 50fps my eyes roll back into my head lol.
p.s. anyone else think that soft shadows need a little work?, it looks like they just set it to render the same shadow 3 times at various opacities
