Just wondering if anyone else thinks these run a bit hot, maybe it's just my chip. My 146 is running hotter then my X2, both with XP90 and I've reseated 3 times now. :stick:
It all depends on the Voltage and the Current it draws...
Optys usually draw less Voltage and a little less Current and are a little bit cooler which makes them better for overclocking...
Let's get past "dope post 1045"..........Quote:
Originally Posted by nn_step
The opty 939’s are no more than an A64 that may, or may not be on better silicone, the jury’s still out. I wouldn’t expect for a moment that a 146 could out perform your X2-3800+ and/or run at higher temps. If you are getting better temps on your dual core than something is clearly different/screwed with your cooling solution, or your application of such………
Of course when AMD realizes, and they probably already have, that we are jumping on the new 939 Opty’s based on theory, they’ll start labeling them according to market demand rather then what we believe works!
3 of my opty runs much hotter than any X2 I've own, though once the IHS is removed they runs cooler than X2....all 3 IHS-less opty gave me about 17~20'C dropped :D :D
Yes they seem to run hotter than the other AMD 64s.
CABYE 0536GPMW is a cool one. Takes 1.6v to get to 3ghz 32M stable but runs cooler volt for volt than any Opty I've tested . Overall the Opties seem hotter, but there may be some cool week/steppings out there.
i don't know about CABYE 0536GPMW being the cool ones....they are bloody hotQuote:
Originally Posted by gundamit
My OEM 146 CABGE (damn you Monarch) runs cooler than my CCBWE X2 4400+ but I won't know the whole story till I get them both in my WC rig.
I'm prolly gonna strip my Opty naked cause it didn't make it over 2.7 on air.
My 148 CABYE 0536GPMW runs very cool! 24ºC 32ºC full at 1.40V, 32ºC idle 39ºC full at 1.50V cooled with an Hyper 6.
Mine must be just a bare core touching the IHS because even @ 1.45 I'm going over 50C w/ my XP90. Too much of a chicken to pop the top :(
