The card
The card
Uhm....where are the results? :)Quote:
Originally Posted by TinTin
The ATItools shows 16pipelines already, flashed by the distributor already, the clock are 499.5/499.5 by default
Some benchmarks results, overclocked, 100% stock cooling :woot:
max-out at about 630/630
nice clocks...... was the card voltmodded?
NO, it is all stock! :)Quote:
Originally Posted by HousERaT
i hate you
SecondedQuote:
Originally Posted by einCe
But then again, I payed $50 less then him, so it's all gravy
where did you get the card? i think it's the best I've seen so far. heck. i am on water 1.7v and i can only get 630 24/7
Super clocks!
Mine's memory is almost as good as that (620 mhz) however i have got a bumb GPU, blacks out screen at 520ish when running atitool.
Congrats on your card! :toast:
Nice clocks TinTin im having problems getting the core over >550mhz windows just crashes. Has anyone volt modded there cards yet and If so what guide did you use.
uber clocks there TinTin!! :toast:
My core maxes out at 580ish. My speeds are set to 579/615. I might do a vcore mod later. I measured it and it is 1.40 V dead on at stock. I'll try 1.45 V. Im only on stock cooling. I want 600 MHz on the core :stick:
Wonder....
Coudn't you increase your CPU speed??
Anyway, have received sapphire X800 GTO²....will test it in a week :(
Your clocks are awesome, futuremark scores aswell :)
Already own a sapphire x800XL
Have been searching thte web to find a way to link two ATI cards on a Nforce4 SLi board....without Crossfire.
Reviewers are right....Why the hell bought a X850 CE when it doesn't support PS 3.0 ??
You should compare your results to X1800XL ;)
Nice...again :woot:
