im looking for pci-e 754 board what can do over 300fsb, but cant find any review :confused:
EPoX ?
EP-8HEAI
EP-8NPAJ
SLi :o
or mb DFI
NF4X INFINITY
EPoX ?
EP-8HEAI
EP-8NPAJ
SLi :o
or mb DFI
NF4X INFINITY
About the 8NPAJ I can give ya some input:
http://mollovshardware.com/pics/s2500_spi16.JPG
And that's not all... the CPU is on it's limit with the BOX cooling... tried it with a VapoLS, but the stupid cold bug throw me away... couldn't run above 320FSB... stupid shiz...
If your going to take a gamble then go with the DFI, they seem to be the best for overclocking.
TodB, that is really good oc, how far does it go with def v, and tell me about bios, mem and cpu extra volts ?
No extra help on the NB cooling, that was with 1.6V I think... you can choose between 1.5V and 1.8V with 0.1V step... with 1.5V I think the MAX was around.... 325MHz... or sumthin like that...
The CPU Vcore goes from -0.1V to + 0.25V in 0.025V steps.. DDR voltage.... 3.1V....
One stable board... but I'm still not sure if there's some problem with the negative CPU readings leading to overclock problems with the VapoLS...
dfi lanparty ut nf3 250gb GET IT lol
yeah, but agp is deadQuote:
Originally Posted by i found nemo
@TodB
what memory did you use in your oc? and what are the timings an frequency also are you using just one stick of ram..
thanks
