Shows up as 1Gb... tried newest BIOS but nothing... still only shows up as 1Gb... worked well on another Chaintech mobo... s939
You have to change in bios CPC for Disable. Then Your memory (4x512) will be work on 2T, and everything should be fine.
Disabled! Everest and CPU-Z shows that it detects all ram but My Computer shows 1024Mb and Everest Summary too, argh
A lil help plz?
Are the two sets different in any way ? Brand.. model.. rev..?
2xPC3200 Patriot TCCD and 2xTwinMOS PC3200
Originally Posted by PlatoonSgtElias
Thats most likely your problem.. Some people get away with two different brands working but sometimes you will end up with the problem like you are experiencing.. Plus it makes it worse when your using two different sets that have different IC's on them, which I think you are doing also..
Ok, ordered 2x1Gb PC3200 Kingston and they will arrive tomorrow :) so if it works then i have 3Gb lol... if not then im gonna use my TCCD Patriots for OC only :-P 317FSB 1:1 bench stable!! :)
7800GTX arrives tuesday and Venice runs 24\7 on 2700MHz on air with a 7v fan cooling it :-P all looks too good :D temps are like 37c.. maybe should test can my processor handle 2800MHz 24\7
Max bench stable was 2936MHz on air
Watch out for Murphy's law :hehe:
