Originally Posted by labrat23
I got all the material from onlinemetals.com The heatspreaders are 1/8" x 1" x 5,1/2". The waterblocks are just 1/8" flatbar with channels cut in them and a piece of sheet metal soldered on to the top. The inlet/outlets are copper tube crushed in a vise over a 1/8" bar for uniform thickness and flatness. The ends were crushed flat and soldered. A rectangular hole was cut in on side of the inlet/outlet so it could feed the waterblock from the side. Also soldered on of course. The barbs are cheap home depot barbs I cut and necked down to fit inside the copper tube. Soldered. Since there is only one tec per ram stick, there has to be a heat bridge/pipe to the other side. That is just another 1/8" piece of copper soldered on. That is the trickiest part. I had to mic the ram and then clamp the heatspreaders over shims stacked to the same width when I soldered it together. It is a tight fit and when I put the clamp on the holds the waterblock on, it is even tighter.
Good luck. I will warn you though that all the ram I tested so far either responds very well or not at all. I give it a 50/50 chance.
