I think I just stumbled across something important.
I posted this on OCF: http://www.ocforums.com/showthread.php?t=392628
I'm wondering what you guys think, and if anyone is willing to try this with their boards?
I just ran a quick test with my DFI nForce4 board, and am totally surprised by the results.
First off, I have noticed that when my memory is overclocked to the point where it starts to cause errors, it always causes errors at the same adresses.
Intrigued, I tried switching the two sticks between RAM slots. Stick one was in slot one, stick two was in slot three - I moved stick one to slot three, and stick two to slot one.
Strangely enough, the errors still occured at the same memory adresses.
But even more peculiar, I found that with the sticks set up one way in the same two slots, they produced more errors than they did when set up the other way in the same two slots.
With stick one in slot one, and stick two in slot three, I averaged ~5.2 errors per pass of memtest86 test #5. With stick one in slot three, and stick two in slot one, I got several hundred errors per pass. I immediately switched them back, and got my ~5 errors per pass again. I switched them back and forth twice to make absolutely sure - the difference in stability (as measured by the number of errors per pass) is signifigant and reproduceable 100% of the time.
What on earth is going on here? Why do my memory sticks appear to "prefer" one slot over the other, of the same pair of slots?
Could some of you please try exactly what I just outlined above, and see if your results line up with mine? You'll need an unstable memory overclock in order to count the errors, and "measure" stability.
...The exact same behaviour occurs with the Orange slots. The difference is smaller, but still present with stick one in slot two, and stick two in slot four, I got about 9 errors per pass of test #5 (I stuck to 15 loops of test #5). With stick one in slot four, and stick two in slot two, I didn't get any errors at all after ten loops of test #5! I tested the Orange slots twice as well - the difference is reproduceable and consistant. My previous testing of the slots had the Yellows giving me better stability, but with rearranged sticks the Oranges appear to actually be better.
I must stress that the same two memory slots were used.
Forgive me if it seems like I'm making a big deal about nothing, but I am astonished and amazed at this. With the same two slots, the memory behaves drastically different depending on which stick is in which slot. I can't believe I've stumbled across this. What the heck is going on with this?
If anyone can spend 15 minutes to test their board out in a similar manner I would appreciate it. This can't be just my board, not with both sets of memory slots behaving like this. For all we know, this has been holding back potential memory overclockability for any number of of people.
If anyone has an explanation or speculation, please share it. I am dumbfounded.
