"NV40+DDR1" WR - 30.9k on 12pipes/6800LE
SillySider03:
CPU/GPU/NB cooled by cold water from a waterpipe.
Difference between Win2k/DirectX8.1b/FW61.34 and WinXP/DirectX9.0c/FW76.50 is a minimum 1000 points. With Win2k + ACPI tweak I got about 200 points vs WinXP on the same settings.
May be your 6800NU is limiting by mobo (MS-7025). I tried to overclock my 6800LE on three different Mobo with nforce3 chipset (DFI LP nf3 UT, MSI K8N Neo2 Platinum, Epox 9NDA3J), but on all got "freezes" and GPU overclock was limited at 380-410MHz. Changing MoBo to Abit AV8 with K8T800Pro solve this problem and after vmods GPU running up to 486MHz w/o "freezes".
BTW, Have you given AM3 a shot?
Yes, I got 82142 points in Aquamark3 and it's WR for 6800LE too :)
http://arc.aquamark3.com/arc/arc_vie...run=1832140611
Wow nice mem clock. Do you have cap mods? My 6800nu maxes at 950 even with 3.3V and cap mods :stick:
Good job beating me though, now I gota bench again...
bugger me that 03 run beats my 03, with 16 pipes! That is mental! That wings of fury is huge!
So you did it again :D
Really nice score, none of your hardwere is really good overclocking but you have really pushed the limits and still got really high numbers , that's most impresing Ithink ;)
The 3dmark03&05 scores is fantastic too, much higher than my 16/6 scores.
SillySider03:
481x1048, I specified clocks in AM3 project name.
On the AM3 Homepage there is a link for a "patch", or hotfix to correctly read the clocks on the newer cards.
Thanks for the info! I download and install this patch so my other AM3 scores will be with correct clocks detected.
btw, I can't understand how Aquamark3 calculate the score...
When I got GFX score 12009 and CPU score 12869 then overall AM3 score has 81878. But with smaller ones (GFX=11949,CPU=12812) I got much higher overall score (82142). Why? :shrug:
afireinside:
No, just Vmem and Vgpu, but no cap mod.
I got a 'blackscreens' only with clocks higher than 464/1050.
Can run memory up to 1063MHz with no higher than 464 at GPU and up to 1050 with up to 486 at GPU. But not 486/1063 at the same time.
464/1063 - no backscreens
486/1063 - blackscreens
486/1050 - no backscreens
Good luck with new benching sessions :)
ZeroHero:
I do anything that I can with my current hardware and now take a break with 6800LE before next upgrage (will try to find a 16/6 one or/and a memory that can run with 1T). There is no "backup" scores. So you and may be others will have time to break my score ;)
Nice scores there.
I wonder if anyone tried the mobile LE's. Those are max 12/6, but maybe because they are mobile they can get some higher speeds on core en memory.
Any PCI-X LE's?
Mobile LE? They make mobile AGP cards? Please enlighten us.
I Thought so. Maybe it was a rumor.
EDIT: I must have misunderstand something.
There are some different 6800Go cards 128bit/256bit low clocks/ high clocks.
But no mobile LE.
Source: AnandTech
