http://bigup.peecee.lir.dk/view.php?id=9124
Stable, gonna take some SuperPI pics tomorrow If I get the time :)
But anyways... T1 260 mhz 2,5-2-2-5 with 2x 512 Crucial Ballistix ;)
- 12k
BTW: No T2 speeds, plz
- 12k
i can do 2.5-2-2-8-10-12 at 250mhz with my EB. im sure if i got more volts i could do more, its only at like 3.1v.
doubt it mate, my previous ballistix did 260 2.5,2,2,5 @ 2.85v and they were not even tracer, whcih I am told can go as high as what WeStSiDePLaYa got.
i can do 265 @2.8V too, 270 isnt far from stable, if i had 3V+ then i might go even further.
targ
My Ballistix 2x512mb:
250mhz 2-2-2-5 3.4v
260mhz 2.5-2-2-5 2.9v (dailyuse)
265mhz 2.5-2-2-5 3v
275mhz 2.5-2-2-5 3.4v
One of the banks do 282mhz 2.5-2-2-5 3.4v :)
hehe ok :) Seems Im outta luck, hehe... :D
Could do 277 mhz 2,5-2-3-5 on my A8N-SLI but that was in T2... My DFI cant go that high, but maxes out same speed in T1 as T2...
- 12k
My old EB (wich I think are the same chips as ballistix) did 265 2-2-2-11 at 3.2 and seemed to love volts that was on my old DFI infinity and the board was limmiting me from going ANY further...BUT that was a single sidded 256 stick...with the heat spreaders off and afan over it...
Dragon
:( i got 2x512 ballistix but i can ONLY do 250 @ 2.5-2-2-6 wit 2.8v my P4C800E-D wont let me use any higher volts.. but im happy with it.. it DOES give me 4Ghz wOOt :banana:
Thought the only difference between Ballistix and tracer is the silly LED flashing lightsQuote:
Originally Posted by qui
unfortunately its not, crucial seem to have put better micron chips into the tracer than those of the normal ballistix, as noted by their noticably higher OC potential.
Not questioning you, but have you any links to this affect :toast:
ermmm, not really, just gauging from what I have experience with my normal ballistix and results I have frequently seen for tracer, if you do a search on this forum for ballistix and also check dfi-street for ballistix, you will see very high scores for tracer stuff, whereas normal ballsitix hovers around 260-270 mark for 2.5,2,2 timings. although my previously ballsitx were quite voltage shy.
I must admit however I have seen very few do a proper prime test @ 10 priority so I am not sure how valid the 260+ HTT ones are.
