I using modbin6 1.00.38 to mod the EpoX 8KDA3I 's bios.but when i done all my job,it can not save !! :mad: why? can you fit it? THX!! :toast:
i gonna to mod the bios so that it can support mobile A64 3400+~~ somebody here can get me a help? THX !!!!
Are you using modbin with Windows XP?
it is recomended to run it with windows 98 / pure dos only :)
or else it wont save... :-/
THX! i will try it~~
Hi.
That is not true that ModBin has to be run in Win98-DOSBOX or in plain DOS.
Poeple who tell such stupid things:
"You have to run ModBin in Win98-DOSBOX or in plain DOS."
have no knowledges about the config.sys/config.nt.
Normally the DOSBOX in Win2K/XP ("command.com" / "cmd.exe") is configured badly.
So ModBin have troubles to load BIOS files and while start or after saving the modification
you will get error messages like these:
Can't open temporary file
File ORIGINAL.BIN can't open
Can't open file 2MBIOS.BIN !
To solve the problem:
Edit the config.nt in your
WinDirectory\System32 as follows:
dos=high, umb
device=%SystemRoot%\system32\himem.sys
BUFFERS=20,0
FILES=30
LASTDRIVE=Z
FCBS=4,0
The important entries are FILES and BUFFERS.
FILES should have the value 30( or more).
After saving the changes you should be able to run ModBin in Windows 2K/XP/... without any problems.
Does not work for me, modbin6 1.00.38
I checked your BIOS file with ModBin6 1.00.38.Quote:
Originally Posted by digitalfrost
There appears another error message which has nothing to do with the current problem.
digitalfrost, in your case you just need a newer release of ModBin. :D
If you want to have it, just get in contact with me.
Thanks Borg, downloaded your BNOBTC, working now :). No more reboots for modbin :banana:
thanks for the info BNO
i never knew that until you post... thanks again :up:
