http://www.dfi-street.com/forum/showthread.php?t=11617
Did you try yet?
nope i dont have a dfi nf4, and i will test on my friends new rig tommorow
Works like a charm - TCCD using 510-3. I could not break 300 Mhz FSB with the 414-3 Bios. I'm priming and Super PI32M at 303 right now I may be able to push higher since I'm only at 1.58 vcore.
The 510-2 bios actually disabled my ps/2 mouse. Not really a big deal, but an annoyance none the less.
I bet if you turn off the power, unplug your mouse, plug it back in, then turn the power back on, it'll work again.Quote:
Originally Posted by UObean
If I were a betting man I'd be a little richer right now. ;) Its not really a big deal though, I can just plug it into a usb port. I'm much more annoyed about these annoying errors I keep getting when I go over 3.2v on the vdimm. I didn't really want to go back to adjusting rails to increase vdimm, but I don't have much of a choice at this point.
Argh, I thought I'd live up to day that a bios update that will SOLVE the dreaded cold boot issue but it seems this day is still away. Flashed 510-2 with my VX and still problems... now even more odd ones. It boots with two sticks and while it shows dual channel and 128-bit, it still recognises only ONE stick, hence only 512MB of memory! Now, THAT'S wierd!!!
I've tried 510-3 and also experienced serious instability. I cannot even boot to bios with a setting that can pass superpi4M. I had to clear the CMOS. It's a setting I'm working on atm and I hoped that 510-3 will bring me that few more Mhz... how I was wrong :(
Such a mix of results out of 510-3 right now....I get my Ultra-D and 3000+ Venice on wednesday so I'll see what BIOS I've got out of the box, give 'er a go...and then see how 510-3 treats me and my PC4400LE 431.
yea its been fine for me.
working pretty good
http://valid.x86-secret.com/show_oc?id=17814
Same as before:
-1 and -3 for TCCD and -2 for utt/bh5?
yep.Quote:
Originally Posted by kiwi
i will try it now :toast:
Just flashed 510-3. My boot time has decreased quite a bit. Surprised it had such an effect.
tried the 510-3 and no difference with the 414-3...
1- tccdQuote:
2- bh5/vx
3- both/misc./generic
Should I move my ram sticks to yellow slots for increase performance on my TwinMos SP 3200 (UTT)?
you should try yellow. for me, orange, i cant break ~235 on the memory. on yellow, i can exceed that. this is on San Diego core.
hmm i do better in orange with my ocz rev2 platinum and san diego....seems to be everyboard and memory is differentQuote:
Originally Posted by pershoot
Originally Posted by cpulloverclock
same here, 510-1 like the 414-1.
is that tccd based ram?Quote:
Originally Posted by stealth17
should I use fast or normal for gskill bh5 ? (currently maxes at 250 @3.5vdimm)Quote:
Originally Posted by Oskar Wu
try normal. if you were stable on previous, then try fast.
How are people updating there bios?
I dont have a floppy disk drive in my pc is there any other way to safely update the bios?
Ive downloaded the 510-1 for my gskill tccd and wanna try it out.
