How tight can I run my TCCD with 300FSB?
I'm running 300 x 9 2.5-3-3-7 @ 2.9v 1:1 1T, is it possible to do better (tighter)?
So far, I failed. Any advises.
FSB Bus Frequency: 300
LTD/FSB Frequency Ratio: X 3.0
LDT Bus Transfer Width: 16/16
CPU/FSB Frequency Ratio: X 9.0
PCI Express Frequency: 100 Mhz
K8 Cool & Quiet Support: Disable
CPU Vid Startup Value: Startup
CPU Vid Control: 1.450v
CPU Special Vid Control: Above Vid * 110%
LTD Voltage Control: 1.20v
Chipset Voltage Control: 1.50v
Dram Voltage Control: 2.90v
Run Memtest86: Disable
MAC Lan: Auto
MAC Media Interface: PinStrap
Machine MAC NV Address: Disable
Internal Phy SATA 1/2: Disable
Internal Phy SATA 2/4: Enable
Si I3114 sATA Raid Control: Disable
VIA 1394 Control: Enable
Marvel Giga Lan Control: Enable
Dram Frequency: 200 (DRAM/FSB:1/01)
Command Per Clock (cpc): Enable
Cas Latency Control (tcl): 2.5
Ras to Cas Delay (trcd): 3
Min Ras Active Time (tras): 7
Row Precharge Time (trp): 3
Row Cycle Time (trc): 7
Row Refrsh Cycle Time (trfc): 14
Row to Row Delay (trrd): 2
Write Recovery Time (twr): 2
Write to Read Delay (twtr): 2
Read to Write Delay (trwt): 2
Refresh Period (tref): 3632
Write Cas Latency (twcl): 1
Dram Bank Interleave: Enable
DQS Skew Control: Increase Skew
DQS Skew Value: 255
Dram Drive Strength Level: Level 7
Dram Data Drive Strength: Level 2
Max Async Latency: 0.8 nano seconds
Read Preamble Time: 0.5 nano seconds
Idle Cycle Limit: 256 Cycles
Dynamic Counter: Disable
R/W Queue Bypass: 16X
Bypass Max: 7X
32 byte Granularity: Disable (8 Bursts)
Memtest86 36 passes (8hrs 25min) 0 errors.
SuperPi 1M & 2M stable.
Not Prime95 stable yet working on it.
