Dual Opteron 250's Overclocking help?
:confused: Basicly I want to get as much out of my babys untill 64 windows comes out properley and more apps work on it, So does anyone no how or can give advise on how to make the dual opterons run faster? 2.4ghz standard, BUT i WANT MORE MORE MORE!! hOPE I'VE POSTED IN CORRECT SECITON :)
Heres the Sandra Specs:
Processor
Model : 2x AMD Opteron™ Processor 250
Speed : 2.39GHz
Model Number : 3784 (estimated)
Performance Rating : PR7168 (estimated)
Type : Standard
L2 On-board Cache : 1MB ECC Synchronous, Write-Back, 16-way set, 64 byte line size
Mainboard
Bus(es) : ISA AGP PCI IMB USB FireWire/1394 i2c/SMBus
MP Support : 2 CPU(s)
MP APIC : Yes
NUMA Support : 2 Node(s)
System BIOS : American Megatrends Inc. 080008
System : To be filled by O.E.M. To be filles by O.E.M.
Mainboard : TYAN S2885 Thunder K8W
Total Memory : 2.9GB ECC DDR-SDRAM Registered
Chipset 1
Model : Advanced Micro Devices (AMD) Athlon 64 / Opteron HyperTransport Technology Configuration
Front Side Bus Speed : 2x 796MHz (1592MHz data rate)
Total Memory : 4GB ECC DDR-SDRAM Registered
Memory Bus Speed : 2x 199MHz (398MHz data rate)
Chipset 2
Total Memory : 2GB ECC DDR-SDRAM Registered
Chipset 3
Model : Advanced Micro Devices (AMD) AMD-8151 AGP Device (System Controller)
Front Side Bus Speed : 2x 597MHz (1194MHz data rate)
Video System
Monitor/Panel : Mitsubishi Diamond Pro 2070SB
Adapter : RADEON X800 Series
Physical Storage Devices
Removable Drive : Floppy disk drive
Hard Disk : 3ware 9500S-:0 Drv 0 SCSI Disk Device (698GB)
Hard Disk : 3ware 9500S-:0 Drv 1 SCSI Disk Device (65GB)
CD-ROM/DVD : LITE-ON CD-RW SOHR-5238S (CD 201X Rd, 52X Wr)
CD-ROM/DVD : LITE-ON DVDRW SOHW-1213S (CD 48X Rd, 48X Wr) (DVD 6X Rd, 6X Wr)
CD-ROM/DVD : LITE-ON DVDRW SOHW-832S (CD 40X Rd, 40X Wr) (DVD 5X Rd, 5X Wr)
Operating System(s)
Windows System : Microsoft Windows XP/2002 Professional (Win32 x86) 5.01.2600 (Service Pack 2)
Chipset 1 Hub Interface
Type : HyperTransport
Version : 1.02
In/Out Width : 16-bit / 16-bit
Logical/Chipset 1 Memory Banks
Bank 0 : 1GB ECC DDR-SDRAM Registered 3.0-3-3-3CL 2CMD
Bank 1 : 1GB ECC DDR-SDRAM Registered 3.0-3-3-3CL 2CMD
Bank 2 : 1GB ECC DDR-SDRAM Registered 3.0-3-3-3CL 2CMD
Bank 3 : 1GB ECC DDR-SDRAM Registered 3.0-3-3-3CL 2CMD
Logical/Chipset 2 Memory Banks
Channels : 1
Bank Interleave : 2-way
Multiplier : 1/12x
Width : 128-bit
Refresh Rate : 5.00µs
Power Save Mode : No
Fixed Hole Present : No
